Great for kids! Revell "Beastie Bug"
Sixtysixdeuce
Post by Sixtysixdeuce »
So, last week I came across these things at T&K hobby. Though they looked pretty good, I could find virtually nothing about them on the web. Perhaps in part because they are new to market, but I suspect more likely due to the fact that when we think of RC cars, Revell is not a brand that comes to mind. But, I figured at $60/ea shipped for a complete RTR (including battery & charger), these would at least work for awhile to get my almost-4 year old twins into something with proportional controls and 4WD capability that will allow them to play outdoors where we live (no pavement besides the garage).
Well, they showed up today. Initial impressions are that they are fairly well made for being just a notch above toy grade.
They are not really 1/16 scale; dimensionally, they are almost identical to the 1/14 mini-8ight.
Specs that you cannot find:
Length: 11.5"
Width: 8.0"
Height: 4.25"
Wheelbase: 7.25"
Weight (w/battery): 2.07 lbs.
Tire diameter: 2.9"
First pic is from Revell, the other 3 I just took:
First, we'll highlight the positives.
-Chassis layout. These things are like miniature 1/8 buggies, right down to the easily serviced differentials with sway bar mounting provisions. The chassis are plastic, but seem robust. All fasteners are button head or flat head socket screws, 1.5mm or 2mm drive, except for the Phillips heads that hold the ring gear to the diff case.
-Drive train. The biggest difference between these and their larger brethren is that they have a typical small scale primary drive train, meaning no center differential or slipper clutch. Just pinion mated to spur, which is rigidly attached to the center drive shaft. Plastic spur, steel dogbone type center drive shaft and steel dogbone axles. True gear differentials with 4+2 steel bevel gears, steel pinion gears, plastic ring gear. The diffs have gaskets and look like they could hold fluid, but I don't think there are O-rings to seal the outdrives. I did not tear it down far enough to investigate that, as the diffs felt pretty good with the heavy grease that was already in them. The Ring and pinion were dry as delivered; probably OK with steel on plastic, but I decided to apply ceramic grease anyway. Diff outdrives are steel, but the outdrive cups are polymer, affixed with pins. Axle stubs are steel with plastic hexes.
-Suspension. Seems to move well, compliant. The arms look sturdy. Camber links are non-adjustable, but that would be easily remedied with something like mini-8eight turnbuckles and Associated 4-40 rod ends and ball studs. The steering turnbuckles are adjustable, with conventional left-and-right hand threads on either end. Shocks are polymer, threaded coil-over oil filled design with captive balls on the bottom. Arms use captured steel hinge pins inboard and outboard.
-Electronics. Simple, but functional. These use an integrated ESC/receiver like the Losi micro vehicles. They are brushed, using a 380 size motor (RS380SM). 2.4 GHz equipped, though the transmitter is very basic, with only steering trim adjustment. Both throttle and steering seem quite smooth for what I would imagine are pretty cheap components, uses conventional forward/brake with double-tap for reverse. Reverse power is about 25%, and is not adjustable that I've found. These come with an 1,100 mAh NiMH pack and wall charger, using miniature Tamiya-style connectors. Battery hold down is a pretty solid plastic strap that uses thumb screws on either end, and serves to route the wires.
Tires & wheels. Seem pretty decent for an inexpensive RTR. Tires are pin-block type, I'd say between a medium and soft compound. The 2.0", 12mm hex wheels seem fairly sturdy.
Now the detractors.....
-Typical RTR. The people assembling do not put the kind of care into it that an owner would. I found several screws not fully tightened
-Suspension links. As mentioned, non adjustable, and do not have ball ends or collars; they move freely by simply not tightening the screws all the way down on them. Steering knuckles are the same way. Tie rods and servo link do use ball studs, though.
-Shocks. Though they are threaded oil filled coil overs, they seem pretty cheap, and they ship dry. There are no bladders or seals for the caps, and the lower o-rings (2 per shock) are not sufficiently squished to seal against the shaft. I simply cut tiny nylon spacers to squash the shaft seal o-rings, and used regular O-rings under the caps, then filled them with 25 wt. They seem to work decent, although I fully expect the fairly loose collars to back themselves off during use, so will probably stick another thin o-ring above them.
-Bushings. That's right; except for one bearing at the spur gear, these things use all plastic and bronze bushings in the diffs and at the wheels. Not too big a deal, with miniature bearings being pretty inexpensive these days. Still, I hate seeing bushings-especially nylon ones. Already did the diffs (one 5x10x4 and two 10x15x4 per diff), but I didn't have the 4x8x3 and 8x12x3.5 for the wheels.
-Motor. It's a cheap brushed can, I think a Mabuchi unit. Moves them OK, but definitely something I will upgrade when either the kiddos are ready for more power, or when they burn up. I may go brushless, inexpensive as it is these days.
-Axles/outdrives. The dogbones have long pins, and the pins will contact the cups before the shocks bottom when the pins are vertical. I will be disassembling again and notching the cups deeper when the wheel bearings arrive.
-Materials. Although the parts seem pretty robust, I can't help but perceive the polymer as being lower quality than true hobby grade cars. Time will tell, but I think I will boil the suspension parts next time I tear them down.
All-in-all, for $60/ea shipped plus another $10 worth of bearings in each car, I think they're a good value. Large & powerful enough to negotiate outdoor terrain pretty well, small & slow enough that you don't have to worry about very young, inexperienced drivers hurting people or damaging property.
I also called Hobbico, the support side for Revell Control, since I couldn't find squat for parts on the web. They assured me that they will fully support these buggies, said just call if you have any issues. They're pretty new to market, but I don't really expect much aftermarket support, even after they've been out awhile.
Will keep everyone posted as to durability & performance (or lack thereof)!
kaiser
Re: Great for kids! Revell "Beastie Bug"
Post by kaiser »
I bet a small lipo will wake them right up.
Revell did or does make a few rtr micro helis that are pretty robust. Our Lhs has a few laying around for kids to play with.
I'm looking at buying a couple of these WLToys L929 RC cars for some 7-year-old girls that are kind of like my nieces (my cousin's twin daughters). When they saw the AYK Buffalo that I restored for my buddy, the first thing they asked was "Can I drive it?" :o
They're also a perfect "decent" RC car for beginners; they're capable of some pretty fast speeds, but you can dial down the max speed, an essential feature for beginners. And the other essential thing? They're cheap...about $35 or so with free shipping...I think they were selling on sale before Christmas for about $27 - $28.
[youtube]dV5pfpshf3E[/youtube]
Sixtysixdeuce
Coelencath-
Those look fun! Too small for out here, though. They look like about 1:24 scale. My Losi micros couldn't go anywhere on my property.
Hobbyking has some offerings that are pretty economical, but not so much when you factor in shipping. It ended up between these and the Exceed mini mad beast at $70. These little buggies are a bit bigger, and the design is a near-carbon copy of the Losi mini 8ight. Time will tell if I made the right choice, but they seem to be pretty good for what I spent. No way I'd have paid the $150 they sell for direct from Revell, though. Not worth that.
These are just a good "kids" size, IMO:
If I'd only been buying for one kid, I'd have probably gone with the mini Rival. But when you have twins, everything costs double....
mk-Zero
Business Member
Has thanked: 4 times
Been thanked: 21 times
Post by mk-Zero »
Thanks for the review, sounds like a fun little car for a kid, especially for the $. I'm going to be in the market pretty soon I think for my 3.5 year old son, I'll keep these in mind. I was thinking about dgtting him a Losi Micro Desert truck, but I'm affraid it would only run well inside and couldn't handle our yard/lawn.
Sixtysixdeuce
I can tell you as a previous owner that those things are indoors or very smooth, paved surface only. They get stuck on/in anything, and a 3/4" pebble will send the 5 ounce truck @$$-over-tea kettle. It was a really neat little RC, but with a small house and dirt driveway, I had absolutely no place to use it, so sold it at a loss.
Even the 1/18 stuff will struggle on grass, unless your lawn is like a golf course. Equivalent to driving a 1:1 car/SUV through a ready-for-harvest wheat field. But at least many of the 1/18 and 1/24 critters are 4WD; the 1/36 Losis are RWD only.
mk-Zero
Business Member
Post by mk-Zero »
Yeah, even my b4 struggles on the lawn, but mostly because it cant get traction. The other thing I was considering for him is a 1/24 losi trail trekker, which I think would be slow enough for him and able to power over the lawn.
Thanks for your advice.
Sixtysixdeuce
We'll find out! Just ordered a pair of 1,700 mAh Turnigy packs. Only $22 shipped for both from Hobbyking, can't really go wrong.
I have no experience with those, but I am sure it will be 1,000% better outdoors than the 1/36 critters. For some reason, I still find myself wanting one of the 1/24 micro truggies. But thus far, I have been able to convince myself I do no need it.
Sixtysixdeuce
LiPo packs showed up today; now the little buggies will do wheelies!
I'm tempted to order up some hotter motors, too, but I keep reminding myself that the kids are not even yet 4 years old, they don't need 20+ MPH RC cars.
Has thanked: 3739 times
Been thanked: 1988 times
mk-Zero wrote:Thanks for the review, sounds like a fun little car for a kid, especially for the $. I'm going to be in the market pretty soon I think for my 3.5 year old son, I'll keep these in mind. I was thinking about dgtting him a Losi Micro Desert truck
Those Losi Micros may be a little too fast for a very small child IMHO. I had one for a while and I'd have preferred it ran slower. They're so small that they seem to be moving a lot faster than they really are and are very twitchy to drive. My dog went nuts if I so much as looked at it so I got rid of it. :lol:
I tend to agree. I think a speed limiter of some sort is essential for the first-time RC newbie (child or otherwise) to learn how to drive RC. Sure, we can turn anyone loose with a high-speed RC, but it's pretty disappointing when they crash and break their new toy right away.
Sixtysixdeuce
I tend to agree.
Me too. They're cute, but can be quite a handful (especially on LiPo & brushless). Kinda the same thing we see in firearms training; a lot of women initially gravitate toward the uber-compact pistols because they are visually less intimidating, but they are actually far more difficult to use than their larger couterparts.
mk-Zero
Business Member
Post by mk-Zero »
that's why I'm gravitating toward something more like a crawler for him, nice and slow and can go over a lot of what he will plow it into, lol.
I'll probably start taking him to a big grassy field pretty soon and start letting him drive my b4 with the throtttle turned way down in the mean time.
tamiya
Been thanked: 9 times
Post by tamiya »
2ch Wheel radios should have a buddy box setup like for aircraft TXs...
icewes
Post by icewes »
[quote][/quote]
For the Lipo's? You need a new charger as well, correct?
I assume so, but thought I'd ask. Thanks!
