novak gtb2 with x drive
- Been thanked: 81 times
New out of box. With power on I am getting a error code red and green light solid. Check input signal harness. I have done that and switched out the harness . Harness is good I checked continuity and it passed. I am stuck at this point . Any sugestions before I send back to novak .
- Blacktiger355
Re: novak gtb2 with x drive
Have you made sure the harness is not flipped backwards on the 3 pins of the esc? With the sensor plug and harness pins facing you, the far right pin of the harness should be the signal or white wire, middle is red, left is black.
- Blacktiger355
- dldiaz
- Has thanked: 41 times
- Been thanked: 58 times
I've made this mistake before, I was super frustrated, called the manufacturer and all - only to have the kid on the phone ask me about the order of the black/white/red wires on my receiver...Blacktiger355 wrote:Have you made sure the harness is not flipped backwards on the 3 pins of the esc? With the sensor plug and harness pins facing you, the far right pin of the harness should be the signal or white wire, middle is red, left is black.
-dldiaz
- 1406 Views
Last post by JosephS
- 1456 Views
Last post by LaserRC10
- 1531 Views
Last post by LemonC
- 2041 Views
Last post by blubblood
- 2376 Views
Last post by teman
- 870 Views
Last post by Frankentruck
- 617 Views
Last post by RC104ever
- 506 Views
Last post by discgolfer72
