Novak 410m5 wire question
- sandkil
- Has thanked: 782 times
- Been thanked: 585 times
Hi,
I'm trying to find periodic correct leads (battery & motor wires) for a 410M5 that i'm to restore. Does anyone know if they are available at all (or just the bay).
I would rather prefer the original type wires then today's glossy silicone wires.
Any help is greatly appreciated
Erik.
Erik.
Re: Novak 410m5 wire question
I am in the exact same situation. Bought a great m5, just need to clean up the wiring. If I come across something I'll let you know.
I'm not like them, but I can pretend...
- 8rad
- Has thanked: 9 times
- Been thanked: 38 times
The 410-M5 came pre-wired with 16awg silicone black and red to tamiya battery plug and blue and black to an associated male plug for the motor.
The wire is clearly marked "NOVAK 16awg". Tamiya battery plugs and associated plugs should be easy to find. Associated plugs are manufactured by AMP.
- Attachments
- mH5CpW1Lr1uXk3lyxvROsLQ.jpg (8.96 KiB) Viewed 1872 times
- Has thanked: 1079 times
- Been thanked: 3718 times
...and are readily available from Digikey8rad wrote:.....Associated plugs are manufactured by AMP.
Factory Works website
- slotcarrod
- Been thanked: 45 times
Any links for purchase of the two pin and three pin connectors ae used?
Rod Littau
Digikey (manufacturer is TE, they sell amps and molex as well)
2 pin Male shells: a1411-nd
2 pin Female shells: a1410-nd
3 pin Male shells: a1429-nd
3 pin Female shells: a1400-nd
Male pins: a97887ct-nd
Female pins: a97888ct-nd
- slotcarrod
Thanks bro!
Rod Littau
- slotcarrod
Looks perfect, nice job!
Rod Littau
- uniquenamehere
- sandkil
Thanxuniquenamehere wrote:Looks great... where did you get the wire?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTGE2&P=7
They have modern prints on em, but they look "ok" in my opinion.
- 865 Views
- 1426 Views
Last post by KidAgain
- 911 Views
Last post by sandkil
- 2000 Views
- 673 Views
Last post by clinehobbies
- 1182 Views
Last post by R6cowboy
- 2477 Views
Last post by Tadracket
- 1447 Views
Last post by MOmo
