Hex rims for '94 YZ10?
- stickboy007
- Been thanked: 17 times
Re: Hex rims for '94 YZ10?
Post pictures, please.
You think the arms are flexy? On the '94 YZ10? Those are solid arms, about as stiff as they get, unless you're used to running aluminum arms or something...
I did have Dynotech generate replicas of the '94 arms, but their machining constraints prevent them from replicating the kick-down in the arms. So their '94 repro arms are flat rather than bent like the originals. Maybe they're a bit stiffer, but again, the stock arms are plenty stiff.
- Been thanked: 10 times
i have a works 91 and they are very flexy ...stickboy007 wrote:Post pictures, please.
send me an pm with youre email and i will send pics.
mvh henrik
- stickboy007
Even the Works arms aren't that flexy. Do you normally use concrete arms or something?
If the pictures are too large, you can shrink them down in MS Paint and post them here. No point sending them to one person when this forum is meant for sharing information like this.
Compared to the arms on My kyosho lazer zxr the arms on My works -91 are very flexy.stickboy007 wrote:Even the Works arms aren't that flexy. Do you normally use concrete arms or something?
I guess thats why those turnbuckles for front susp on the works -93
Yeah but i cant get to My photobucket account egen i can i Will post them here so for now those Who want to see
I can email .
Med vänlig hälsning, isobarik
- DennisM
- Has thanked: 30 times
- Been thanked: 64 times
When You originate from the country of Volvo, You don´t want wobbly stuff on Your carstickboy007 wrote:Even the Works arms aren't that flexy. Do you normally use concrete arms or something?
Gone fishing
- stickboy007
Haha...
I'll have to check my ZXR to see if the arms are more "solid" than the Works arms. Maybe they are, but I have a Works '93 runner and it's fantastic, "wobbly" arms and all.
The small turnbuckles for the front (and rear) arms in the Works '93 are actually to reduce bulkhead wear. By tightening it down, it presses the hinge pins against the bulkhead, thereby forcing the suspension arm only to rotate on the hingepin, rather than having the hingepin rotate inside the bulkhead and wear it out. Easier to replace worn plastic arms than work aluminum bulkheads.
aha i mean the ones in the front that goes to the uprights seams like they are there to stop the arm from flexing to much .....
mvh isobarik
mvh isobarik
- stickboy007
Oh, the torque rods. Their primary purpose is to limit fore/aft play in the castor block.
aha ....they stpped the flexing also ...and lett when he won the worlds well....the arms was not originals,,.....stickboy007 wrote:Oh, the torque rods. Their primary purpose is to limit fore/aft play in the castor block.
mvh isobarik
- stickboy007
Nope i dont have but i would guess in the scans sectionstickboy007 wrote:Do you have a picture? It would be nice to see what arms he used.
Mvh isobarik
- Has thanked: 135 times
- Been thanked: 23 times
- Attachments
- 1989 Masami Yokomo.jpeg (128.26 KiB) Viewed 1183 times
here you go .....
mvh isobarik
- 1102 Views
Last post by kaszal
- 572 Views
Last post by klavy69
- 1258 Views
Last post by buttmonkey1969
- 3781 Views
Last post by Ronbo
- 129 Views
Last post by Toaster
- 870 Views
Last post by civilguy
- 962 Views
Last post by highwayracer
- 1323 Views
Last post by Jschoenb
