Sourced new bulkheads, motor mount is on the way, and cut out a fresh chassis
I would love to find a jammin upper brace and battery straps to copy if anyone has em laying around
This is how she started
And the "progress"
That's a fresh chassis, cut from a sheetTypicray@rainmans wrote:That chassis cleaned up REALLY nice!
Yes! I use a vac, sucks up all the dust and a dust mask just in case. I have heard how bad carbon can be but funny enough the guy that sells the carbon says he won't touch g10 because it's far more dangerous to the lungs. Weird!Charlie don't surf wrote:I have NIP towers you can use as a template if the ones on there are altered- I also have a couple of sets of white bellcranks if you don't have new ones-
make sure that you are using a serious air draft or filtration system when your grinding on that stuff!
We used a dry-wall 5 gallon water filtration system that used a vacuum for suction but didn't run the crap through the actual vac...then just dump the black water and rinse the bucket. Cheap (20-25) and doesn't trash your vac or shop vac-gomachv wrote:Yes! I use a vac, sucks up all the dust and a dust mask just in case. I have heard how bad carbon can be but funny enough the guy that sells the carbon says he won't touch g10 because it's far more dangerous to the lungs. Weird!Charlie don't surf wrote:I have NIP towers you can use as a template if the ones on there are altered- I also have a couple of sets of white bellcranks if you don't have new ones-
Charlie don't surf wrote: Coal miners don't get black lung from fiberglass
Yokomo Z-500 narrow wheelshondaman wrote:Gomachv nice project.. looking good..
stickboy007 those wheels are probably cut versions of the stockers.. way too thin compared to the narrow yz10 wheels..
Shawn
