RC 10 Anodizing
- Been thanked: 6 times
RC 10 Anodizing
Does any one do or know if anyone who can do QUALITY anodizing for an rc10 chassis parts set for a reasonable price?
- Has thanked: 822 times
- Been thanked: 2418 times
Re: RC 10 Anodizing
Nope! Quality and good pricing do not go hand in hand. There is a ton of labor that goes into a good finish, and labor is expensive. My anno guy is cheap but they don't even look at the run, its my responsibility to clean and polish and whatever else to make the metal right. Cheap isn't good and good isn't cheap
Factory Works website
Re: RC 10 Anodizing
I just want to send it out and have it done RIGHT. What can expect to spend and who can I trust to do just that??
- THE H.P FREAK
Re: RC 10 Anodizing
Does it need to be stripped first? If so, plan to send it out, and once it's stripped either pay them to polish it or have them send it back so you can, then they can get to the anno. If you strip and polish before you send out it will save a lot of time and a little money.
Re: RC 10 Anodizing
Easy off oven cleaner I am told works well. Personally I have the anodizer do it, runs $20 for a whole load. Unless you have one close by tho it will be easier to just do it first. The better you can polish the metal the shinier the anno will be. If it's old metal and scratched up don't do the bright dip as it will highlight problem areas. If it's fresh metal, eg a classic kit, then a bright dip will make the finish look almost wet. On the classic shock bodies I have they almost appear to be leaking oil they are so shiny
Re: RC 10 Anodizing
damn that easy off, cant find one here , can someone ship it here in Singapore. please...the problem now is , is it allowed via airmail?
― Confucius
― Confucius
Re: RC 10 Anodizing
I doubt it!
I wonder if there are other easier to find chemicals.....I'm not that guy but maybe someone will chime in
- THE H.P FREAK
Re: RC 10 Anodizing
HI!... Greased Lightning also takes off anodizing.
- Phin
- Has thanked: 61 times
- Been thanked: 182 times
Re: RC 10 Anodizing
Sodium Hydroxide (lye) is the stuff in EO that removes anodizing.
Other brands of oven cleaners should work too, or you can try drain cleaners mixed with water.
Re: RC 10 Anodizing
i have tried those that are available here but to no avail... wish those can be shipped via mail so that I could remove annod on my stuff....
― Confucius
― Confucius
Re: RC 10 Anodizing
It is new metal from classic kit want to do black i guess i cld try some of these products gomach r u saying that u do anodizing?
Re: RC 10 Anodizing
No, but I do have a shop that is local to me and they do a good job on the cheap. If you are working with classic parts you don't need to go thru all the polishing and cleanup steps, I would just talk to an anodizer and have them strip and anno. The shop I use would charge $60 total ($20 strip and $40 anno) plus shipping. If you did a bright dip it adds $30.
- 20 Replies
- 1700 Views
Last post by flipwils11
- 703 Views
Last post by kenooze
- 919 Views
Last post by KidAgain
- 1528 Views
Last post by helbnd1
- 916 Views
Last post by jh1985
- 662 Views
Last post by Qballll
- 746 Views
Last post by mrhemi1971
- 952 Views
Users browsing this forum: No registered users and 38 guests
