original TRX1 shocks springs
peuge73
Has thanked: 5 times
Post by peuge73 »
I would like to know what set of springs I can use on the TRX1 / Eagle LS shocks ?
Original spring set seems to be hard to find, or uncomplete.
Does Associated sets fits well ?
What's the good solution for rear and front ?
Hugues
local club president, but also family team manager - mecanic - official sponsor, and some times cruising my RC cars......YES!!!!!!!!!!
http://www.bmvrc.com/
Re: original TRX1 shocks springs
I believe a losi spring is a better fit, slightly larger OD.
peuge73
Post by peuge73 »
thx for your answer. What losi springs ? The XXX one ?
In fact,here is the whole issue:
I will race a traxxas car in 2014 (just a few times).
Here is how it begins:
and nearly the actual situation :
rear side
front side
I'm looking for the right solution for shocks.
I have rebuilt the original ones, but the diaphragm is no more efficient. Only still here for seal.
Also, I need a complet spring set (one for front and one for rear).
But in fact, is this the good idea too race them ? I think a more up to date shock set would be better.
What is your point of view ?
Original shocks with Losi spring sets ?
the hard anodized traxxas shocks are still available, as are the rebuild kits. There is really nothing wrong with them unless they are worn out. Losi springs from I beleive any buggy, jr series, xx, triple x probably all fit, but I'm not well versed in what size spring is on what vehicle.
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
I've had alot of good luck with the traxxas hardcoated shocks. Ive used mostly traxxas springs on them though. Never had enuf money to experiment with all the springs but a few of the locals used Losi like stated above. I Had to just experiment around with spacers and shock oil weights but got them 'workable' with the traxxas springs.
peuge73
Post by peuge73 »
Thx for your interest.
jwscab wrote:the hard anodized traxxas shocks are still available, as are the rebuild kits.
Ok for the complete shoocks availability.
Fot the rebuilt, as I cannot find it neither on the bay and A-main, I used 2362 ref, witch is for actual shocks. Orings and clips (etc) are OK except the diaphragms.
I am looking for rebuilt kit ref 1662 or diaphragms ref 1665. still not found at the moment.
klavy69 wrote:I've had alot of good luck with the traxxas hardcoated shocks. Ive used mostly traxxas springs on them though. Never had enuf money to experiment with all the springs but a few of the locals used Losi like stated above. I Had to just experiment around with spacers and shock oil weights but got them 'workable' with the traxxas springs.
I have seen that TeamC TC02T springs were OK. It is a first step. Just a remark: they have really horrible colors...
I'm checking also for the right travel stops, in static first.
harry697
Post by harry697 »
For a rebuild kit, the 2362 stuff will work. The bladders are a bit larger but will work fine. They take a little more effort to get them seated into the shock cap though.
As far as springs for the original shocks, I haven't had a whole lot of luck with that. Losi springs are much larger diameter. Associated springs are very close in diameter, but are a little smaller than the stock springs and require a bit of effort to get them seated onto the spring retainers properly. I had trouble finding correct length AE springs for the front of the TRX-1 shocks. I'm sure there's something out there, but all I had to work with was some tuning spring kits I had laying around for my T4 and B4. The truck fronts were too long and the buggy fronts were way too short.
Best thing to do IMO is get a set of Traxxas big bores. Direct bolt-on replacement. Had them on my TRX-1 and they worked great! Also, Losi XXX springs are a perfect fit. You'll need the 2660 fronts and 2661 rears. Not only was it a nice upgrade over the stock shocks, but my LHS also has a wall full of Losi springs, so no more hunting down springs. :mrgreen:
My old TRX-1 with BB's and Losi springs:
peuge73
Post by peuge73 »
Great answer, very clear.
I think it is a good shock solution for racing back my eagle LS.
My actual shocks are eeven not teflon coated. Just a question of budget at the moment. Racing will be for summer 2014, and I still need some extra parts.
Hugues
Return to “Traxxas Forum”
