Kyosho NSR500 old decal problems
- slapshot1979
I am building a kyosho NSR500 (rothmans) from NIB and have spend ubar amounts of time seam sanding painting building etc. I had a look at the decal sheet for the first time out of package and some of the sheet has lifted from the backing. I can assume that it has lost its stickiness. it is about 20+ years old. Is there a product I can use to apply these. ie make em sticky again. I am shooting for perfection not a CA type fix.
Thanks
Thanks
- Has thanked: 1129 times
- Been thanked: 3917 times
Re: Kyosho NSR500 old decal problems
Good question! I have a couple motor labels that have lost their sticky too. Looking forward to an answer!
- shodog
- Has thanked: 3 times
- Been thanked: 91 times
3m makes a tape called pressure sensitive adhesive. It's basically just the stick'em that is about 5mil. I use it for aerospace applications.
- slapshot1979
3M™ Electronic Double Sided Tape 82610
3M(TM) Electronic Double Sided Tape 826XX3M(TM) Electronic Double Sided Tape 826XX3M(TM) Electronic Double Sided Tape 826XX3M(TM) Electronic Double Sided Tape 826XX
3M™ Double Sided Tape 82610 is a 0.10 mm high tack acrylic adhesive on both sides of a thin polyester film. The high tack adhesive provides high initial adhesion and good shear holding power to a variety of substrates.
Features and Benefits
•Instantaneous good tack and adhesion.
•PET carrier is dimensionally stable and easy to die-cut.
•Excellent shear strength.
Application Battery Bonding, Battery Door Attachment, Camera Module Assembly, Case Assembly, Electronic Component Bonding, Foam Bonding, Foam Gasket Bonding, Logo Bonding, Memory Card Bonding, Module Bonding to PET Card, Rubber Feet Bonding, Speaker Module Assembly, Touchpad Assembly, Touchpad Bracket Assembly, Wire and Cable Clip Attachment
Application Category Bonding
Backside Adhesive Thickness 1.75 mil
Backside Adhesive Thickness (metric) 0.044 mm
Backside Adhesive Type Standard Acrylic
Backside Liner Color White with 3M Electronics Print
Backside Liner Print Type Polycoated Kraft
Backside Liner Thickness 5.2 mil
Carrier Color Clear
Carrier Material Polyester
Carrier Thickness 0.50 mil
Carrier Thickness (metric) 0.012 mm
Carrier Type Polyester
Faceside Adhesive Thickness 1.75 mil
Faceside Adhesive Thickness (metric) 0.044 mm
Faceside Adhesive Type Standard Acrylic
Liner Thickness 5.2 Milli-inch (mil)
Liner Thickness (metric) 0.13 mm
Liner Type Polycoated Kraft
Operating Temperature Range (Celsius) Long Term (Days-Weeks) 93 Degrees C
Operating Temperature Range (Celsius) Short Term (Minutes-Hours) 150 Degrees C
Product Series 82610
Substrate Foam, Glass, HSE Plastics, LSE Plastics, Metals
Total Tape Thickness without Liner 4.0 mil
Total Tape Thickness without Liner (metric) 0.10 mm
Carrier Color Clear
- slapshot1979
Sorry for the huge post. I dont know how to link another page etc>
Is this the stuff?
Is this the stuff?
- 1544 Views
Last post by rc10johnny
- 751 Views
Last post by body snatcher
- 2637 Views
Last post by R Cane
- 2929 Views
Last post by AscotConversion
- 21 Replies
- 2154 Views
Last post by railey72
- 966 Views
Last post by Quikenuff
- 1420 Views
Last post by RC10th
- 741 Views
Last post by tulsa
