turbo optima mid se body
Rigs
Post by Rigs »
Hi too all
Just a quick question about how to repair a cracked body and also what other body can i adapt for this car.
mikea96
Has thanked: 659 times
Been thanked: 878 times
Re: turbo optima mid se body
Post by mikea96 »
I have used shoe goo on the inside before as it stays flexible. As for a replacement body there are several reproductions on ebay with and without decals.
zuki250
Post by zuki250 »
This guy has really nice bodies....and he is actually a really nice guy...got me some info that i needed without even asking ...thought it was really cool, i am buying my optima body from him
http://www.marwanrc.com/
Been thanked: 3917 times
Most of my bodies are TBG so don't get me wrong, but the holes will be off, and the fitment will be off from stock by a bit. The bodies are a tad smaller, and although it isn't a huge deal-DONT use the dimples to drill your holes! Ask me how I know :mrgreen:
I agree, Marwan's bodies are noticeably more detailed (you can see the body lines & cut lines more clearly) and will trim & fit almost perfectly. TBG bodies are all a slight bit undersized as his are bodies-molded-from-bodies, not made from actual molds. They'll work but require a bit more effort to trim them properly. On the downside, a shipped Marwan body is darn near a $60 body after all is said and done. It's worthwhile if you buy multiple bodies and have them shipped together, or if you're doing a shelf-queen; but for a runner, a little work and saving some money is also a good thing. Those are your pros & cons. :)
HKS_TRD
Post by HKS_TRD »
I thought the Marwan bodies were also undersize?
I know the LWB Optima Mid under tray definitely is
I have a couple genuine Optima Mid bodies I will have to compare to the Marwan one sitting on my SE-X
rccars4sal
Post by rccars4sal »
My marwan lwb opt mid body and tray fit fine. I messed up by using a lazer type rear shock tower which made the rear clearance funky,, but other than that,, the tray lined up fine with the holes on chassis, and body fit fine.
Return to “Kyosho Forum”
