Servo mount
General info, Q&A.
DMAT
Servo mount
Post by DMAT »
This has just been bugging me lately, With the nose plate mounted, the servo mounts are at 2 different heights, I can mount the servo w/o issue like this but it sorta bugs me that they are uneven.
Do yall ever do anything to counter that?
Has thanked: 359 times
Been thanked: 471 times
Re: Servo mount
BITD they trimmed the nose plate to correct it
clm
Has thanked: 100 times
Been thanked: 205 times
Re: Servo mount
Post by clm »
Or, as on the t2, placed a spacer under the rearmost one to raise it up to be level.
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
DMAT
Re: Servo mount
Post by DMAT »
clm wrote:Or, as on the t2, placed a spacer under the rearmost one to raise it up to be level.
Chris
This is what I'm doing, just adding a washer under it.
clm
Re: Servo mount
Post by clm »
Use the too-small spacers that they provided for the rear shocks.. I think that's what the t2 used actually ;)
Chris
Y'ernat Al
Has thanked: 7 times
Been thanked: 17 times
Re: Servo mount
Post by Y'ernat Al »
If it's a car I want to lighten up for racing, the nose plate will be cut, otherwise, I just slice a thickness off the bottom of the front mount:
Which I think is easier an cleaner than spacers.
- Brian -
My Gallery
SteveK
Re: Servo mount
Post by SteveK »
Chris
The Classic manual calls for two #4 aluminum washers, seems to work fine.
