can we do a JRX "tips, tricks, re-fits and how-to's" thread?
perry
Has thanked: 5 times
Post by perry »
...or is there one already and I haven't seen it?!
I was going back and reading that traxxas bandit sliders can be fit very easily to replace the stock losi ones, and realized there isn't a consolidated thread for all of the retrofit, and compatible parts.
I was hoping to get that going, and if you guys could help me by giving me links or posting up what you know, I will try to edit the first post to reference information. I just don't know any of that information, and I figured there is probably a lot that you guys do know that could be shared.
here's the Bandit slider axle info:
pmathews924 wrote: One thing I found out last night (on this forum actually) is that the Traxxas Bandit uses (almost) the same slider axle. From what I read I'll have to modify the pin hole slightly to fit the yoke, but I can deal with that. A set of Bandit axles is going to be around $6 (compared to $30+ for a set of white sliders), and my local shops might actually have it. The plastic isn't 20+ years old, it's new, and it's designed to hold up with newer technology...and from what I've seen so far Traxxas stuff is usually pretty durable.
Been thanked: 3919 times
Re: can we do a JRX "tips, tricks, re-fits and how-to's" thr
Generally you would just start a thread and use a title that gets people in and posting. Once it takes off, try for a sticky
LosiXXkid
Post by LosiXXkid »
gomachv wrote:Generally you would just start a thread and use a title that gets people in and posting. Once it takes off, try for a sticky
Come on! The Losi Forum needs at least one sticky - the RC10 guys have loads going on... :mrgreen:
mytimac
Business Member
Has thanked: 7 times
Been thanked: 56 times
Post by mytimac »
#1 tip of all time.
Always run your molded chassis Losi with the top brace securely fastened on. :)
perry
Post by perry »
mytimac wrote:#1 tip of all time.
:lol:
Of course, we wouldn't have to worry about it so much if "someone" could make a re-pop chassis to replace it with. :idea:
If you guys are willing to post up your ideas, tips and knowledge, I will try to consolidate all of it into a new thread and ask for a sticky.
mytimac
Business Member
Post by mytimac »
perry wrote:Of course, we wouldn't have to worry about it so much if "someone" could make a re-pop chassis to replace it with.
I shudder to think of the tooling costs for that one. The XX front bulkhead is scary enough at this stage.
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
Just reproduce the jrx pro graphite chassis and lengthen the back and add the extra holes so it can be used on the lxt as well ;)
That should suit 6 kits right there, everything except the jrx2. Although likely only for runner use.
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
geeforce59
Post by geeforce59 »
clm wrote:Just reproduce the jrx pro graphite chassis and lengthen the back and add the extra holes so it can be used on the lxt as well ;)
Chris
That's great, maybe i can have one of those jrx pro chassis :D
biff85ta  It’s my birthday!
Post by biff85ta »
Chris
LXT and Pro SE have narrow chassis. Not a big deal on the LXT but the the Pro SE body won't fit over the the Pro chassis.
"It is not how you finish but how you qualify unless you qualify bad then it is how you finish."
Words of wisdom from the Cox bros at my local track.
clm
Post by clm »
True, but it is easier to remove material then add it, a chassis cut to wide specs is less then half inch away per side from narrow, which could be slight extra cost or a diy thing. Alternatively you just run a junior 2 body as you are building it to run instead of restoring it moving from molded to carbon, it would be the one size/shape that would be usable on most of the early cars.
Chris
Return to “Losi Forum”
