TRX1 Build
- dave00beer
- Has thanked: 9 times
- losiXXXman
- Been thanked: 5 times
- Seabass
- Business Member
- Been thanked: 12 times
Re: TRX1 Build
Thanks guys, I originally had plans for an upper brace but I want to run the car without it first because there is going to have to be a couple modifications to the front bulkhead and shock tower. The CF I used has a good bit of flexibility and may work well for the car. No way to tell how the car will react without driving it.
I ordered the turnbuckles tonight which will give me time to finish up the front axles since they have to be machined from billet aluminum to meet my needs for this car. Basically I need to install the turnbuckles, machine the front axles, finish the steering, install the electronics and paint the body. More pics coming in a few days.
I hope the car drives good, if it doesn't it will go on the chopping block.
- Supernaut
- Has thanked: 5 times
- Been thanked: 66 times
Re: TRX1 Build
Awesome project. I love that chassis.
I am still waiting for mine to be made so that I can get my build going.
If I would have made the MOMUS CNC I was planning to make this year it would have been done.
Love to build......need to practice painting
Associated - Worlds, B6D
Traxxas - Rad2, TCP, Stampede, Villain IV
Tamiya - CLODBUSTER
As you can see....I sold most of my cars. Funding Pinball now.
Tamiya - CLODBUSTER
- Seabass
- Business Member
Re: TRX1 Build
Well I just figured out I need to order some more parts. I am trying to adapt B4 wheels to this car but the wheel fitment is driving me nuts. The problem is Traxxas made this car with metric hardware and I am trying to put non-metric stuff on the car. I first thought I could turn the rear axles on the lathe to the 3/16 OD required for the AE wheels. I did that with success but the wheel fitment is a bit sloppy because the rear axles are just not long enough to get a solid fit.
The plans - I am going to take measurements to identify the length of the CVDs I need and order the 3/16 bearings. I am going to turn a spacer out of nylon to fit in the Traxxas hub so the 3/16 bearings fit snug. I have done this before to fit bearings and it worked perfect. I am going to turn new tranny outdrives to accept the CVDs. This way I don't have the problems with having the proper length axles and the rear should be set.
The front - I am going to turn new front axles that will fit the Traxxas steering arms but accept the 3/16 front bearings for the B4 front wheels. Yes I know that I could just buy 2.2 Traxxas wheels but I have several cars that run B4 wheels and I don't want to have to buy multiple sets of wheels and tires due to the expense. Regardless of the car I want to run, I grab all my wheels and tires and go. It is a pretty decent way to have multiple cars and keep the cost of wheels and tires down.
This by far has been the most annoying part of this build and I have not had this many problems from any of the other cars I have built. I am starting to lose interest on this one quick because it is starting to piss me off. I hate this cause I have been wanting to build one of these cars for a while now.
- Has thanked: 10 times
- Been thanked: 445 times
Re: TRX1 Build
What will you be using for cvds? You need cup joints on the trans side or keep the sliders. If you get a set of the output yokes (plastic or steel) you can turn a set of axles that are 5mm at the bearings and 3/16 on the wheel as long as you want and use the output yokes on those axles.
- Seabass
- Business Member
Re: TRX1 Build
I did turn the 5mm axles from the OEM sliders down the first time but the axle itself is not long enough to give the wheel proper support. After tightening everything up the wheel still has some play and slop.
I just measured the B4 CVDs and they are too long. I also happened to have a set of rear B44 and they are still a tad too long. After spacing the axle properly in the outer hub, the CVD is about 3/16 too long.
UGH!
UGH!
Re: TRX1 Build
right, i got what you said up there with the stock axles, I was talking about making a new set of axle shafts to your liking, spacing, etc, then putting the drive yokes on them. so the rear axle stub would be a two piece assembly.
are you using the trx1 rear hub? If so, won't the B4 wheels end up narrowing the width? You could put B4 rear hubs on and that should give you 3/16" or so. Just have to watch the clearance on the arm, the B4 hub positions the axle closer to the hing pin, although with a CVD and bone you get a lot of clearance over the sliders.
- Lonestar
- Has thanked: 626 times
- Been thanked: 166 times
Re: TRX1 Build
Losi sliders?
- Seabass
- Business Member
Re: TRX1 Build
SOB, you guys are right. I just happen to have a set of Losi axels here at the house. Let me get them mounted to the Traxxas sliders to see if it will work. Will post results.
- 57 Replies
- 3534 Views
Last post by Lavigna
- 35 Replies
- 3587 Views
Last post by moto-steve
- 1951 Views
Last post by spennyy2k
- 1798 Views
Last post by chriswolfson
- 23 Replies
- 2246 Views
Last post by Konich
- 911 Views
Last post by Bullfrog
- 737 Views
Last post by Mr. ED
- 21 Replies
- 2357 Views
Last post by RedScampi
