How to: rebuild bottom loaders with Traxxas 2362 kit
- Has thanked: 1129 times
- Been thanked: 3919 times
This is a popular way to rebuild your bottom loaders. I would still recommend using associated cap and shaft orings
Rebuild in the same was as the manual shows, using associated orings in place of the blue ones shown in my pics.
You can use the diaphragms if you wish, i find that they don't seal well. Standard cap orings are better.
I recommend green slime during install, it will help keep from cutting the o-rings and make the assembly easier
Re: How to: rebuild bottom loaders with Traxxas 2362 kit
Just took a quick look- the clips are much smaller on the kyoshos, and the bottom washer is much larger as well. The narrow washers look usable, and the thick spacer is too thick. Looks like we are better off looking elsewhere. I bet I can find clips, and I know I can get orings lol...the thick spacer would be the toughest part
- RC10th
- Has thanked: 52 times
- Been thanked: 1548 times
So why did you put the blue rings in?gomachv wrote: Rebuild in the same was as the manual shows, substituting the blue x-rings for the orange o-rings.
Is the height of the traxxas seals/spacers the same height as Associateds?
don't use the blue x-rings. I found them to not seal well in these bodies.
The spacers are the same size as associated.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
I was just looking at Custom Works MDX shocks and they use a clip like the Kyosho Golds but not sure about the size. Guide washers look like they've got potential to replace the Kyosho spacer as well.gomachv wrote:Just took a quick look- the clips are much smaller on the kyoshos, and the bottom washer is much larger as well. The narrow washers look usable, and the thick spacer is too thick. Looks like we are better off looking elsewhere. I bet I can find clips, and I know I can get orings lol...the thick spacer would be the toughest part
http://www.customworksrc.com/CategoryProductList.jsp?cat=Shocks+and+Springs
- 1735 Views
Last post by lifeIsAnalog
- 2231 Views
Last post by R6cowboy
- 29 Replies
- 7030 Views
Last post by Nick
- 551 Views
Last post by DMAT
- 738 Views
Last post by daniels9424cs
- 687 Views
Last post by Barnfind
- 474 Views
- 3746 Views
Last post by kaiser
Users browsing this forum: Google Feedfetcher and 5 guests
