10T Chassis
10T Chassis
I'm starting to clean/assemble my Ebay 10T and noticed that the rear of the chassis seems to be bent a little. Should the whole chassis be flat or is there a little bit of angle to the rear portion of the chassis? I'm going to be seriously pissed off if this chassis is a write off.
RC10 Short Arm | Novak Tempest ESC | Tamiya Torque Tuned 25T | Savox 1258 | Stealth Trans w/ Exotek Slipper Eliminator (geared 24/81)
RC10B3 | HW Just Stock Club Spec | Reedy 13.5 | Savox 1258
Re: 10T Chassis
I just put the damn thing on the table and the whole chassis does not sit flat. Damn thing is tweaked.
- Has thanked: 1130 times
- Been thanked: 3920 times
Re: 10T Chassis
Most of em are. Find a nice sturdy table and slowly and forcefully bend it back. It'll go
- huminski
Re: 10T Chassis
yup shoulld be completely flat, the only kick-up is in the nose plate which is a separate piece, and the rear up-curve around the motor.
They usually straighten out pretty well just be patient, you can make it worse if you rush it or get frustrated.
Re: 10T Chassis
I'm going to get another chassis. This one is going to be raced so I want to be sure the chassis is right otherwise the suspension geometry will be off and cause funky handling.
Re: 10T Chassis
I highly doubt the suspension geometry with be off and exhibit funky handling with a slightly bent chassis, nor would you be able to tell in any way, especially if you are running it as a truck with big balloon tires.
you can easily straighten it out with a vise, some wood blocks, maybe a 200lb'er stepping on it in just the right spot. you can also tweak by flexing the sides in or out to get what you need.
Re: 10T Chassis
I have found the rear of the chassis can end up bent upwards if the holes in the chassis and the motor plate don't line up before you screw them together. Use some aluminum spacers in between the chassis and the motor plate to keep the chassis flat.
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: 10T Chassis
race a new chassis and it'll match the original one sooner than later...ca-rj wrote:I'm going to get another chassis. This one is going to be raced .
Re: 10T Chassis
+1.race a new chassis and it'll match the original one sooner than later...
Even the hell-for-stout blue tub GT chassis get tweaked. These things take some serious abuse on the track.
Re: 10T Chassis
I'd rather start out with a non damaged chassis than one that is already tweaked.
- Been thanked: 4 times
Re: 10T Chassis
runner chassis are pretty cheap.But im cheap so id straighten it.Not very hard to do.don
Re: 10T Chassis
After I've built my truck and I'm bored, I might try to straighten it out.
Re: 10T Chassis
Spare chassis tubs tend to turn into whole vehicles after some time. Fair warning.After I've built my truck and I'm bored, I might try to straighten it out.
Re: 10T Chassis
Tis a possibility. So far this month I've acquired a Classic, 10T and just bought a CE.
- 718 Views
Last post by mikea96
- 2461 Views
Last post by K-TOWN-KITT
- 2326 Views
Last post by Ucsdmutt
- 37 Replies
- 6407 Views
Last post by Jim85IROC
- 1087 Views
Last post by MOmo
- 743 Views
- 853 Views
Last post by tulsa
- 1245 Views
Last post by treehugger
