On/Off switch replacement for Novak Explorer
unclemikey1978
Post by unclemikey1978 »
I have a used Novak Explorer esc that is missing it's on/off switch and the white wire that goes to the receiver has been cut. Is it possible to replace both the white wire and the switch on this esc? If so, will a newer Novak switched work? Can I just solder a piece of wire onto the receiver lead? Thanks in advance for your replies.
Justin33
Re: On/Off switch replacement for Novak Explorer
Post by Justin33 »
Yup just solder away a new switch will work fine just be carefull when soldering to the board use a nice hot iron and select your tip carefully nice and small so you dont spread heat to parts you dont want to
integra22t
Post by integra22t »
this might help http://www.rc10talk.com/viewtopic.php?f=78&t=28465
i would recomend a 25-30 watt pencil tip iron, fine solder, solder wick or vacume .. if your good at soldering you should be fine .. if not just take it to an elecrtonics repair shop and let them do it
Users browsing this forum: No User AvatarGoogle [Bot] and 4 guests
