Vintage Optima Mid Upgrade Parts
OK so the title is a little open ended but I thought it would be cool to get a list and even better some pics together of all the different vintage upgrades that were available.
I'm a big mid fan so keen to see from that perspective but also I have a NIP Trinity SWB saddle pack chassis which I want to build up with vintage upgrades if possible, I'm not sure what was out there to know what to target, especially things like upper decks and shock towers.
Maybe this tread could be a sticky for all of us mid fans out there
Re: Vintage Optima Mid Upgrade Parts
Well, just off the top of my head, theres the finned motor plate spw2, lm-15 motor cooling plate, any kind of adjustable turn buckle from Kyosho or aftermarket, ball diffs....A&L trailing arm chassis,, A few different makes of shock towers.. Im not aware of any much else like top plates, or other chassis.
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Keep in mind that SPW-2 and the gear cover might not work together nicely.
Here's some bits that ought to fit:
Kyosho:
- W-5111 front one-way
- 92501 rigid axle
- SPW-1, 2, 3, 4 TF-1 (narrow SWB Optima Mid) swing bar set, motor plate, carbon chassis, toe in rear plate set
- xxxxx (unknown number) TF-1 two-speed transmission
- 1710 special antenna holder
- 39502 HG quick body mount (if used on a Scale Car Optima Mid)
Aftermarket:
- alloy c-hubs, front uprights, rear uprights, king pins, etc. for Kyosho Spider/GP-10 cars
- alloy arms and universals for Kyosho wide GP-10 cars
Manufacturers to choose from: Cross, Kose, Atlas, Central RC, Fivestars, GPM, AR Racing, etc.
Kyosho:
- 92501 rigid axle
Aftermarket:
- j0pp3
- Been thanked: 4 times
JG Optima Mid Bumper
JG Optima Mid Body
JG 1505 Rear Body Mount Kit
Thorp 4665 Joint (outdrives)
Thorp Dirt Burners 5050 Rear Diff
Thorp 5020 Gear Set
Thorp 4441 1/16 Steel Balls
Thorp pinion gears
Alec & Lane (A&L) steering kit
Alec & Lane (A&L) trailing arms conversion kit
SRS Graphit chassis and upper deck
And some pics with options:
JG Optima Mid Body
Thorp 5020 Gear Set
Thorp pinion gears
Cheers
Joel
Joel
I remember reading the advert for the bullet products. Wow factor there. The heat sink motor plate looks nice. I thought either kyosho or option house had a finned motor plate specifically for the buggy mids, but all I could remember is the spider motor plate. I totally forgot about the factory 1 way front diff,, and its strange because my current built mid has that. Mids are my current passion, so ill be following this closely. In a rusted heap,, I just received a complete turbo mid se with all the factory goodies still on it! Rough, but complete and correct. Thats a highly optioned buggy right outta the box. Had never seen a correct one till now. That jg chassis looks nice! I have been searching for the spider option chassis just for the bling effect,, but the jg would do just fine!
- DennisM
- Has thanked: 30 times
- Been thanked: 62 times
Cool Joel, thanks for sharing -
Now we just need pictures of Your PK saddlepack chassis
That´s my favourite 3. party upgrade.
And I never even had one - just a homemade copy in softice aluminum.
Gone fishing
Thank you everyone for posting pics of ads, lists etc its much appreciated.
I will post pics of the parts I have here when I get a chance
I've been busy with work etc and dummying up all the parts for a new project .....
- Has thanked: 170 times
- Been thanked: 23 times
Could you please repost some pictures joel!j0pp3 wrote: ↑Sat Sep 28, 2013 6:35 am JG Optima Mid Bumper
JG Optima Mid Body
Thorp 5020 Gear Set
Thorp pinion gears
- 878 Views
Last post by tamiyadan
- 3092 Views
Last post by HatTrick
- 1494 Views
Last post by j0pp3
- 853 Views
Last post by suedespade
- 892 Views
Last post by racingkids
- 3190 Views
Last post by Bo Wallen
- 19 Replies
- 9154 Views
Last post by lin6499
- 664 Views
Last post by madmaxx
