Found an RPM gear cover...and I can't get it on the car.
pmathews924
Post by pmathews924 »
After searching for a while I finally scored the much sought-after RPM cover for my LRM slipper set-up, and I can't get anything on the forward-most screw. The old scans say to use a nylon 4-40 nut, and the smallest one I could find doesn't fit. Went to the hardware store and bought the smallest 4-40 nut they have, and that doesn't fit either. It fits the screw, but there isn't enough room for it to turn on the threads.
I read something about super gluing a washer to the end of a ball cup...is that the easiest or best way to attach this stupid thing?
Losi Jrx2 Pro
Kyosho Big Brute (work in progress)
LTO_Dave
Has thanked: 52 times
Been thanked: 287 times
Re: Found an RPM gear cover...and I can't get it on the car.
Post by LTO_Dave »
You might be able to grind a flat spot on one side of the nut, hold it against the cover with your finger, then thread the screw into it.
Been thanked: 3919 times
Pretty sure we ran a small pattern locknut on those but it's been a while.
Associated 4449 should do the trick. They are a 3/16 head instead of 1/4. Same as the hex on a ball joint
clm
Has thanked: 100 times
Been thanked: 205 times
Post by clm »
You know what would work really well? One of the earlier Associated ballcups that only had a hex near the cup, cut the cup off and you have a long nylon 4-40 nut that is smooth for more clearance near the gear cover :)
Chris
Mini - T, LST, LST2, Crawler
Micro - Trekker, SCT, T
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Post by aip47-2008 »
BID we used an old worn out long losi ball cup, cut off the end and used a short socket head cap screw on one end and screw it on against the gear cover.
Worked like a charm. Or just use the entire worn out ball cup with your fingers.
pmathews924
Um...that looks like the ticket for sure! I'm going to go hack up an old ball cup right now.
Losi Jrx2 Pro
DerbyDan
Been thanked: 19 times
Post by DerbyDan »
I use a small peice of rubber tube (peice of wire with the strands removed) its just a tight push-on fit but works OK.... think I might try the ball joint trick as that looks like it could be more secure?
By the way - you'll find that the slider driveshafts foul the u/side of the cover when the suspension is under full compression - I used a hairdrier set on HOT to heat up the plastic locally & re-formed the cover with a peice of aluminium tube to gain the necessary clearance :wink:
Return to “Losi Forum”
