Losi JRXS Belts
knixdad
Losi JRXS Belts
Post by knixdad »
I'm going over a JRXS roller I just picked up and I am at a roadblock due to belt issues. Namely, I can't find the front belt either as a Losi part or from any companies that produce these kinds of belts. I've found sources for the rear belt, but the front seems to be some magical size that isn't a normal production item.
Front Belt: LOSA3301
Pitch Length: 330mm
Tooth Pitch: 3mm
Width: 3mm
Tooth Count: 110
Does anyone have a source that they go to for belts like this? It doesn't match any other Losi belt. And the JRXS Type R belts are completely different, since the motor is mounted in a different spot.
aip47-2008
Has thanked: 170 times
Been thanked: 23 times
Re: Losi JRXS Belts
Post by aip47-2008 »
knixdad
Re: Losi JRXS Belts
Post by knixdad »
I can't believe this place didn't pop up when I was searching. Thanks!
Return to “Losi Forum”
Users browsing this forum: No User AvatarAhrefs [Bot] and 4 guests
