needing help on my b4.1 worlds
Forum rules
judd75
Post by judd75 »
I put the kit together by the book. Took no short cuts. The perfomance is less than desireable
Any ideas to getting this car running better?
Been thanked: 3917 times
Re: needing help on my b4.1 worlds
More power is always the key 8)
But seriously.... What are you looking to improve?
romulus22
Has thanked: 900 times
Been thanked: 789 times
Post by romulus22 »
Pictures
What aspect(s) of performance are less than desireable? Acceleration? Top speed? Handling? :?
judd75
Post by judd75 »
I think I just higher expectations. I mean coming from nitro 1/8 scale to a 1/10 buggy is jard to get used to
judd75
Post by judd75 »
Handling. And speed both. Im just not sure what electronics to put in it.
With the right choice of electronics, you should be able to get that b4.1 at least as powerful (or moreso) than with nitro, with a fraction of the noise & fuss.
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Post by Lonestar »
Simple question - are you running on a racetrack? Go try it at a racetrack... not a backyard. It's a 2wd racecar designed to race in the 2wd category... not a backyard basher.
if power is the key, and you want thrills comparable to 8th nitro 4wd, you will be disappointed. It's smaller, light, nimble, and 2wd only. The only place where it will be comparable to 8th nitro is on a 500m straight line so you can get up to top speed. Overpower it, and all you will get is bald rear tires. But take it to a properly designed racetrack for 10th scale offroad and it will run circles around any 8th nitro ;)
Paul
foots
Post by foots »
Lonestar wrote:Simple question - are you running on a racetrack? Go try it at a racetrack... not a backyard. It's a 2wd racecar designed to race in the 2wd category... not a backyard basher.
Paul
What Paul said
judd75
Post by judd75 »
im stationed in ALASKA no race tracks here. but after some mods im pretty well satisfied..thanks for all the comments
judd75
Post by judd75 »
but i would liketo ask what motor and esc will make this car smokin fast.. im only using what i had on my b4.2rs rtr
Justin33
Post by Justin33 »
Tekin rs pro with 5.5-6.5 tekin gen 2 on 2s will get that thing running super fast if not fast enough program some boost and timin into the esc just watch your gearing things might get a little hot otherwise :)
Chris00gt
Post by Chris00gt »
Another vote for the Tekin RS-Pro with the Hot-wire setup. The ESC fit's perfect under the body, and with a Gen 2 Tekin 6.5 motor you'll be more than happy!! The hard part will be running the slipper loose enough to keep the front end down and not to break anything ;-).
NEW: SC10 4x4 FT, SC10 FT, (2)T4.1 FT, B4.1 World
OLD RC10's: (4)Worlds, Graphite Team Car, (2)RPM Ultra's, Tekin, B2 Team Car, B3, (3)Champ Editions, Team Car, (2)RC10T Team Truck
Tamiya: Hornet, Fox
Bolink: Invader
Losi: (2)XX, Junior 2, JRX Pro SE
soniccj5
Post by soniccj5 »
Running an 8.5 in my B4(with +8mm) and it FLYS! I only run it on a track, and have never driven a 1/8 anything.
judd75
Post by judd75 »
I went with. Castle creations I bought the sidewinder. Stuck with stock gearing. And it seems to be running how I wanted it to. I cad ro modify my body casuse of the large fan on the esc. But im jist building this for fun not races. I also modified my body by cutting the body down half an inch or so to have it lay down flatter and just have a lower look. And this damn thing skoots.
