very simple very good modification
What do you like.
I put an front bodypist from an tamiya tc car to the rear brace and it go through the wing and then close it whit an bodyclip.
Now it wont come loose the wing.
Jerzi
Jerzi
Re: very simple very good modification
After all these years that we have had problem with loosen wings but not any more.
Jerzi
Jerzi
- integra22t
i use to put a couple of small bends in the wire that fits the tubes and it would fit snug .. i think ive only lost 1 wing while racing .. boy did it suck
- atarit3
Neat Idea!
I've had that same problem over the years. bending the wire didn't help. I finally ended up getting some kyosho rear wing mount and it mounts B4-style. I left the body mount and simply cut the back of the body off and left it there, heavy duty velcro for the body.
http://www.rc10talk.com/viewtopic.php?f=35&t=30474&start=15
- Attachments
- RC10 wing mod r.jpg (45.86 KiB) Viewed 986 times
"To finish first, you must first finish"- Rick Mears
http://www.facebook.com/YumaRCRaceway
http://www.facebook.com/groups/rceofyuma
- RC104ever
I did the wing wire bend, helps a bit but honestly I went for the el cheapo solution and just use some clear tape on the top when I go out driving. I do have some B4 wing mounts and a rear shock tower from RC Carbon Works but too lazy to do all that work
But your idea is a very clean and elegant solution!
- Chris
Lots of cars...so many cars
- 873 Views
Last post by Alex B
- 424 Views
Last post by Erich Reichert
- 796 Views
Last post by JK Racing
- 374 Views
Last post by tim.sanderson
- 663 Views
- 1706 Views
Last post by Maxell27
- 749 Views
Last post by Mr. ED
- 969 Views
Last post by honkinberry
