RC12i independent front suspension manual
The place for digital versions of catalogs and instruction manuals.
tiger1
Been thanked: 7 times
Post by tiger1 »
Hi:
Any one has the manual for the independent front suspension of the RC12i??
Also, what will be the parts to use the contemporary bolt to hold the tire and rim rather than the ancient E-clip?
Thanks in advance :)
camlchris
Re: RC12i independent front suspension manual
Post by camlchris »
tiger1 wrote:Hi:
I may have the manual for u. PM me your email. I will try to look for u.
The answer is no ! The front wheel stub with 4-40 thread of modern pan car is much longer than the stock stub.
tiger1
Post by tiger1 »
Thanks and thanks.
So there is no chance to use the newer front wheels on the 12i....
camlchris
Post by camlchris »
tiger1 wrote:Thanks and thanks.
You can use the newer front wheels since their off-set is nearly the same. You need to shim it to get the right front track width and use the old fashion E-clips to hold them.
tiger1
Post by tiger1 »
thanks
Return to “Vintage Catalogs / Instruction Manual Scans”
