3D Printing an RC10 Chassis
ROH73
Been thanked: 23 times
Post by ROH73 »
I should be working on my 20 other RC projects, but instead I decided to model the aluminum RC10 chassis and massage the design to make it 3D printable out of ABS plastic (which is obviously WAY more flexible than 6061-T6 :D ). The printer I have at work only has a 6"x6" platform, so I had to break the chassis into three parts (as shown by the different colors) that can be screwed and glued (maybe solvent welded) together. I'll be printing with a 20% fill. That means that the interior volume of the parts will be hollow and filled at 20% with a roughly 1.5mm x 1.5mm square lattice. This reduces weight and makes the part stiffer than if it was solid.
This project is for fun and there will be quite a bit of trial and error involved until I get parts that I can join together and mount up to the rest of an RC10.
I printed the back section today (only took 2 hours! :mrgreen: ) and already saw that that motor guard section needs to be thicker. The model pics reflect that change.
Any comments are appreciated.
flipwils11
Been thanked: 19 times
Re: 3D Printing an RC10 Chassis
Post by flipwils11 »
That's pretty cool and looks promising.
CamplinP
Post by CamplinP »
Nice. Some notches could be put into the front bulkhead to use chassis stiffeners if needed. Looking forward to seeing the final.
ROH73
Post by ROH73 »
Thanks! I thought about the stiffeners too; they could probably run over the top if needed or I can just get out the ol' dremel and make some notches after the fact. :D
RC10resto
Has thanked: 1488 times
Been thanked: 550 times
Post by RC10resto »
That's gonna be tough to Ano :lol: 8)
RichieRich
Has thanked: 39 times
Been thanked: 25 times
Post by RichieRich »
I like it. I think it should work out well, I mean Tamiya uses nothing but ABS on most of their chassis.
integra22t
Post by integra22t »
i want a 3d printer and scaner so bad anymore
looking good so far, robert. :wink:
ROH73
Post by ROH73 »
The ABS should be strong enough in theory, but an injected molded chassis is stronger than a printed one, so we'll see. The interior lattice helps on stiffness, but not on impact. :wink:
Many members of The Open RC project use ABS and same type of printer. It seems to be going well for them, although several people have switched to nylon: https://plus.google.com/communities/112745535856143176146
It's about time to upgrade my printer to one that easily prints with nylon filament :D .
ROH73
Post by ROH73 »
Thanks, Jason!
Jedi Master
Post by Jedi Master »
That's very cool! 8)
Do, or do not! There is no 'try'!
RC; Boats, Buggies, Trucks, Bash's, Racing and of course 'VINTAGE'!
My Ebay Feedback: http://feedback.ebay.co.uk/ws/eBayISAPI.dll?ViewFeedback2&userid=jedimaster768&ftab=AllFeedback
RC104ever
Post by RC104ever »
Wow, that's really awesome! Can you print using nylon instead of ABS? Can't wait to see the finished product.
- Chris
Lots of cars...so many cars
ROH73
Post by ROH73 »
I can print with nylon on my printer, but it's more challenging to use than ABS as the nylon absorbs quite a bit of moisture and must be dried prior to use. I may try to order some next week and bake it in one of the lab ovens at around 110 C for a for a day or so.
I'll probably make a run with the ABS first as it's cheap and I have 6 spools in 4 different colors (black, red, white, green and blue) at work.
DMAT
Post by DMAT »
oh nice. someone else who likes the cad side of things.
what kind of printer are you using. I've been wanting to get one but dont really know whats good.
I never saw the open rc project so thinks for that.
I've done some cad models of several parts so far, It may just be a starting point but if you want some model files, I can send them to you.
just a thought but maybe you can determine a ratio for the thickness increase when comparing nylon to aluminum. might help for some parts.
Has thanked: 3699 times
Been thanked: 1980 times
Great project Robert. You're just a bit ahead of the rubber-band/balsa racer I've been working on. :oops: I think a 1/18 RC10 would be a cool project. Maybe steal a transmission from an existing model or go direct drive. :mrgreen:
Users browsing this forum: No User AvatarAmazon [Bot] and 4 guests
