Ultrasonic Cleaner
Mattesch
Ultrasonic Cleaner
Post by Mattesch »
Ok - so I recently bought a World's car to restore. Following the guidance of some previous posts, I thought I would give the $29 Ultrasonic cleaner a shot, along with a Hydrogen Peroxide solution. So far, I am not too impressed :-)
Been thanked: 3919 times
Re: Ultrasonic Cleaner
That's because your using hydrogen peroxide. I use "LA's Awesome" cleaner in mine from the dollar store, although simple green or other cleaners will work also. Hydrogen peroxide isn't a cleaner. That's used to whiten the parts in sunlight. I would not recommend a cleaner that doesn't have heat either, the heat helps a ton.
Edit- or did instead your post incorrectly? Maybe you cleaned first then put in a bath. I'm unclear.
Mattesch
Post by Mattesch »
Ok - thanks for the recommendation on the simple green - I will hit that first :-)
Also, about the unit with a heater - I am too cheap, so went with the Harbor Freight variety.
Mine is also harbor freight, just the next model up. If you water down your simple green use hot water.
RC10resto
Has thanked: 1488 times
Been thanked: 550 times
Post by RC10resto »
and separate the plastics and metals.
Groomi
Post by Groomi »
They work great as a cleaner - I use mine all the time. Mine was an equally cheap one (in the UK) but a different make and although it isn't advertised with anything about a heater, I find if it is left plugged in for about 30 mins then it does heat up. Often particularly dirty parts take several cycles, during which time it has heated up anyway. To aid heating up, only put just enough water in to cover the parts and for cleaning of plastics I put a good blob of washing up liquid in with it.
Using my son as an excuse to relieve my youth. :lol:
https://www.facebook.com/MuzzoomModels
