A-Main Bullet Fwd 4ws RC10 conversion Tribute build
- romulus22
- Has thanked: 612 times
- Been thanked: 624 times
Re: A-Main Bullet Fwd 4ws RC10 conversion Tribute build
I don't like when people leave the body clear but this car is almost too cool to cover up. Great job or re-creating this car.
- Has thanked: 792 times
- Been thanked: 2262 times
It would have been hard to cut if not clear. This was the runner body, it's going to be a template for the good body
Factory Works website
- Phin
- Has thanked: 60 times
- Been thanked: 179 times
Cab forward bodies would've plagued us a lot sooner.gomachv wrote:... Makes me wonder if they hadn't changed the rules where fwd would be now
Very cool work. You are on a roll with your recent projects!
GARBO 1/8
I just read through this thread and love the project. I have always thought about making a front wheel drive buggy to see how it would drive. I can't wait to see the maiden voyage. I like Joey's thinking on a stealth with 2.2 wheels!
A stealth and 2.2's are very doable.pumpkinfish wrote:I like Joey's thinking on a stealth with 2.2 wheels!
The problem occurs with longer arms and the kyosho hubs, if you look at my 4wd thread you will see how far I had to narrow the bulkheads to make standard arms fit.
- JK Racing
- Has thanked: 103 times
- Been thanked: 199 times
After taking the time and building my re-re 6 gear with outdrive bearings and spacers (by taking time, I mean more than the couple minutes I usually take to assemble a trans) I am not opposed to a 6 gear. With JC coming out with "small" wheels/tires, the 2.2 route could also come into question
Very cool build.
Very cool build.
I was told by the owner of the competing hobby store back in the day that they had to run the VW bodies to help them roll back onto their wheels in the corners lol. No cab forward for you!
- Phin
Cab forward bodies was tongue-in-cheek thinking designers would use the cab to cover the front trans. But more seriously, if FWD took off, maybe we might've seen some more experimenting with limited slip diffs for 1/10 electric RC.
I'm going to use a 6 gear and will test out one of these PN Racing pan car spurs. Don't have much faith in them but it seems interesting. If I were going to be trying to build an actual FWD racer though I think would try and do a custom belt trans using a Kawahara negative diff for a V One R or MTX3.
Interesting I like it. Just wonder if it will truly lock up. This would be an ideal component if it worksPhin wrote: I'm going to use a 6 gear and will test out one of these PN Racing pan car spurs. Don't have much faith in them but it seems interesting.
- Phin
I'm very skeptical that it will lock up well...or even that the oil in the "reservoir" won't just all leak out...but for just $10.00 it's worth a shot.gomachv wrote:Just wonder if it will truly lock up. This would be an ideal component if it works
Georg Kotzinger supposedly ran (runs?) a B4 with a limited slip diff. Haven't seen any pics of it's insides but I can imagine it'd possible to build something like a Kyosho Inferno TCD out of an aluminum gear diff case for an SC10.
I've come to the conclusion that I can't afford to have a custom set of chassis laid up for this, so for now I decided to send her out to have her "carbon fiber" parts anodized black. At least it's closer to the feel of what it should look like
- 1522 Views
Last post by LTO_Dave
- 38 Replies
- 4929 Views
Last post by templeofspeed
- 1194 Views
Last post by matt1ptkn
- 3478 Views
Last post by Lonestar
- 20 Replies
- 2928 Views
- 19 Replies
- 3933 Views
- 980 Views
Last post by hugger19
- 47 Replies
- 9162 Views
Last post by johnekb
