Running 2.2" rubber on your Losi jrx2/pro/SE/junior
- pmathews924
How do y'all do it? I've heard a couple different methods but wanted to see if there's some kind of consensus...
Losi Jrx2 Pro
Kyosho Big Brute (work in progress)
- Has thanked: 822 times
- Been thanked: 2418 times
Re: Running 2.2" rubber on your Losi jrx2/pro/SE/junior
I just opened a set of duratrax nitro evader wheels (dtxc9848) and if it weren't for the long wheel pin they would fit great and clear the 5 link
Use shorter pins or cut down stock ones and you'd be fine
Factory Works website
- pmathews924
I have the parts, but I'm not going to run a 5-link...running h-arms in the rear.
But those wheels will fit on the stock axle?
Sucks they don't come in orange!
Losi Jrx2 Pro
It slid right into my Jrxt, it's a good tight fit on the axle. At most you may need a washer before the nut- that's one thing I didn't check cause I ain't cutting my wheel pins
- highwayracer
If I remember correctly, there were a couple different versions of wheels for the evader. Some were made out of a brittle plastic material...while others were nylon. I don't remember which is which.
Has anyone looked at the wheels from the thunder tiger buggy (phoenix)? If it's a clone of the b2/b3, I wonder if the wheels will fit as well.
You can use wheels for the Associated B4 (front and rear) directly on an H-arm car (I don't know about the 5-link). I used an extra rear axle spacer (the one that fits between the pin and hub bearing) on the front spindles to space the wheels out a little farther. Otherwise, they just drop right in.
Keith
Keith
- pmathews924
Sweet...so sounds like I don't have to change axles anywhere...just find a wheel that fits and (maybe) insert a spacer.
I'll be running h-arms, so no need to worry about 5-link clearance.
Losi Jrx2 Pro
I know you aren't running 5 link, my statement was that the Duratrax would clear just in case someone later finds this thread so I don't have to take the wheels off my truck again lol
- pmathews924
Haha...and I still have the 5-link parts if I ever decide to run the car that way, so good info to know!
Losi Jrx2 Pro
- sgirouard
Fronts, you can use B4 rims with a spacer or Duratrax evader rims (although they break easier)
On the rear, I've found the easiest solution is to use a 12mm hex over the original pin and use Jammin CRT.5 rims. They have more offset than most 2.2" rims.
http://www.amainhobbies.com/product_info.php/cPath/1_25_1461_634/products_id/13840/n/OFNA-Dish-Wheel-Yellow-4
- JK Racing
- Has thanked: 103 times
- Been thanked: 200 times
How would we ever know about that thread with a generic title like "How to run modern rubber on your JRX series car"
/sarcasm lmao!
/sarcasm lmao!
- JK Racing
I have another thread about using B4 wheels all the way around on a 5 link...I just havent dug it up yet.
http://www.rc10talk.com/viewtopic.php?f=27&t=23998
- highwayracer
What's a JRX cargomachv wrote:How would we ever know about that thread with a generic title like "How to run modern rubber on your JRX series car"
/sarcasm lmao!
Seriously....good info...thanks for posting.
- 1324 Views
Last post by tamiya_d1_junky
- 1135 Views
Last post by pmathews924
- 885 Views
Last post by GJW
- 1420 Views
Last post by RCveteran
- 23 Replies
- 3633 Views
Last post by sgirouard
- 2159 Views
Last post by hugger19
- 363 Views
Last post by Snaab9-2
- 44 Replies
- 8249 Views
Last post by stevejc
Users browsing this forum: Amazon [Bot] and 17 guests
