RC1 vs. RC2 what´s the difference?
- Been thanked: 100 times
This time not going for the 1/8 thread.
What´s the difference between RC1 and RC2 1/8 car? Was the RC2 released later or is it a different version of the RC1?
Can´t find anything on this.
Re: RC1 vs. RC2 what´s the difference?
After reading trough old pricelist (thanks Al) I found out now what´s the difference. Actually RC1 and RC2 are the same car, the difference is just rear axle and motor mount. The RC1 is using an onepiece unit where the RC2 is using four parts. The RC2 parts were easier to make but alignment was much more critical.
- reign79
- Has thanked: 3 times
- Been thanked: 4 times
Well not exactly.... The original rc1 or more correctly the morrissey special had separate rear axel mounts that were aluminum and then stamped steal also double stamped steel motor mounts. The progression and updating of parts for the rc1 was very fast in the beginning. The same goes for the front end and wheels to match, not many people know but I will let the cat out of the bag ,there is actually four versions of the rc1 front wheel that eventually became the rc100 and rc200 front wheels. Also two different materials.......... Well I could go on forever but the skinny is the rc2 is a rc1 with early version parts they could have just called it the early rc1 and the one with the new parts the rc2. Also the the original flywheel was black anodized steel(very heavy) and spur gears were black.
Ryan
This is interesting informations, thanks. What are the differences on front end and wheels? The problem is there are no early catalog available for checking and it seems now newer catalog is not showing the correct informations or parts. Trying to show some of my wheels later.
So the morrissey special maybe was the prototype then? Not the RC1 first version production car?
Do you know when the first Associated lexan bodies were introduced? Is the Porsche 917K Coupe the first of their bodies or maybe more the McLaren M20? I really like the 917K and glad I found one. Don´t know if there had been other versions than the one sold (but not made) by Associated.
- reign79
Yes they were raced as the morrissey special before they were sold as the Rc1 by the Balnel racing team at the series 70 race in St Louis 1971. The first bodies were made by Jim Kirby before associated began making there own bodies, the fist bodies were the TI-22 the Gurney Eagle and the lotus 72. The wheels well I would have to talk on the phone to explain as my fingers might cramp up
feel free anyone to pm me your number and I can explain!
Ryan
- reign79
Ohh there's also three different chassis. The original chassis is 4"x16" with the rear axle mounts all the way back and three different front end holes for different wheel base settings with the wing mounts in front of the rear axel. The second chassis came 1" shorter with a space behind the rear axel for wing mounts and fuel tank mounting, also the front end was pre drilled for front bumper. The final version has only one set of holes behind the rear axel for new aluminium wing mounts that also hold on aluminum fuel tank mount the front axel only has one set of holes and there is also the addition of pre drilled holes for access to the motor mount screws under the chassis!!
Ryan
i have a set of rc-2 motor mounts. I have a complete rc1. ill post pics when I learn how-first time.
- reign79
There's no rc2 motor mounts there just the early original rc1 mounts #803 before the one piece motor mount came out #808
Ryan
- mrlexan
- Been thanked: 12 times
Screw the differences.... More importantly, what's that pic from V12?
www.gojammedia.com
www.gojammedia.com
- mrlexan
Easy answer.... some are upstairs in the spare bedroom and some are in the garage.reign79 wrote:.......more importantly where's Mr Lexans 1/8 cars
Next Question?
www.gojammedia.com
www.gojammedia.com
- mrlexan
It does feel good to have all your stuff in one state, Finally..... after 3.5 years of being away.
www.gojammedia.com
www.gojammedia.com
What do you think it is?mrlexan wrote:Screw the differences.... More importantly, what's that pic from V12?
It is not an empty box.
- 1544 Views
Last post by GreenHell
- 912 Views
Last post by j-sou
- 31 Replies
- 3949 Views
Last post by airbats801
- 2228 Views
Last post by RC10resto
- 841 Views
Last post by reign79
- 947 Views
Last post by a01butal
- 1375 Views
Last post by badhoopty
- 2651 Views
Last post by beardxxxd
