Losi XX fitting Trinity blue transmission brace
Hi All,
Does anyone remember if you are meant to use washers under these to bring the height of the brace up more in line with the lip of the shock tower ? (presuming that's where the alloy tab braces to?)
Without any washers there is about a 3-4mm difference between top of tranny case andand the shock tower lip which would create a fair angle/gap without any spacers?
cheers
J
cheers
J
- works92
- Has thanked: 85 times
- Been thanked: 32 times
Re: Losi XX fitting Trinity blue transmission brace
if you talk about this one, no, no washers use to fit it...
maybe you can post a picture of the problem... it will be easier to help you.
Hi
Thanks for reply, will get pic when at home but it's a different brace, without the sides, just a simple flat tab with no side arms. i.e it doesn't screw into the shock tower at all.
More shaped like the one someone made from the composite rear arm mount section in another thread on here?
Sorry not very helpful I know with no link but on tiny phone screen at mo.
Cheers
Cheers
- slapshot1979
nope that style isnt tied to shock tower at all. only strenghtens the trans area
Ok i get you, basically just creates a thicker tab. Presumably the curve edge faces rearwards?
- slapshot1979
I dunno, I would assume so, Mine are square and dont have rounded edge.
- 2359 Views
Last post by LosiXXkid
- 1670 Views
Last post by mrhemi1971
- 716 Views
Last post by Erich Reichert
- 650 Views
Last post by RCveteran
- 1050 Views
Last post by Soncho Ponza
- 2487 Views
Last post by trek
- 402 Views
Last post by tecnica2001
- 3306 Views
Last post by TRX-1-3
