stealth trouble
stealth trouble
having trouble with my stealth tranny because it seems like one wheel is not supplying as much as the other but when I took the tranny apart it looked fine. is this normal??
- soniccj5
Re: stealth trouble
The only thing I can think of is a problem with one of you axles. It would be worth checking the differential and cleaning it up, but that should not cause one wheel to spin faster in a stealth.
Re: stealth trouble
It is if you have a bad hub bearing, or one wheel torqued down tighter than the other one.
- RC10th
- Has thanked: 40 times
- Been thanked: 1017 times
Re: stealth trouble
If the wheel has been over tightened it will rub the hub and lock up, this is bad on original RC10 rims as there is only one pin slot and cant really be repaired.
Re: stealth trouble
Just bought a B4 'ex racer' and this had a completely seized axle - I had to press the bearing out of the hub and off the axle itself. Root cause probably overtightened wheel nut as the bearings spun freely and smoothly once removed
Re: stealth trouble
i've had this happen on my b4. car seemed so weird.works92 wrote:I bet on a seized up bearing on the diff. output
i started with the hub and worked my way back to the outdrive. thing was seized solid.
- RC10th
Re: stealth trouble
Crush tubes weren't included with the RC10RC10th wrote:Was the crush tube in the hub?
- RC10th
Re: stealth trouble
No they weren't, I was reffering to the two prior posts about the B4, where it's nearly impossible to over tighten a wheel.
Re: stealth trouble
my issue was with the outdrive bearing, it was original, old and served it's time.
- 712 Views
Last post by Barnfind
- 486 Views
- 300 Views
Last post by fakiee
- 1811 Views
Last post by oldskoolracer
- 994 Views
Last post by Rustbucket
- 790 Views
Last post by Hanetrain
- 24 Replies
- 3019 Views
Last post by longboardnj
- 759 Views
Last post by CON2
