shocks
shocks
I have cleaned my rc10 and replaced the oil in the shocks to find that two of them leak.. does anybody know what size the o ring is or where to get them? (if you need a picture of the shock let me know)
- markbt73
Re: shocks
Rebuild kits are still available... new top and bottom O-rings included. If your shocks are "bottom-load," you won't be able to use the little O-ring clips in this kit, but the O-rings themselves should be the same size.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2593&P=7
- jaro
Re: shocks
I recently rebuilt some bottom load shocks with the O rings from the rebuild kit. Shafts were rather pitted in my case so I replaced them at the same time and all is now fine.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LX2594&P=ML
- RC10th
- Has thanked: 55 times
- Been thanked: 1587 times
Re: shocks
I've noticed the orings have changed size over the years, they seem to have gotten larger, or looser on the shaft.
Check the shaft for scratches, make sure you dont over fill the shocks and use green slime on the seals.
- 1286 Views
Last post by adam lancia
- 1062 Views
Last post by coxy-ben
- 1000 Views
Last post by Bugle
- 791 Views
- 504 Views
Last post by mikea96
- 561 Views
Last post by justinspeed79
- 620 Views
Last post by HotRodJosh
- 691 Views
Last post by XLR8
