I'm looking for new outdrives for my t3. Can anyone tell me if i can use the ones from Custom Works ? Are they better then the ones from Thunder Tiger?
And what about the Custom Works GBX Differential. Is that the same as my standard T3? It appears the Custom Works Differential uses two ball bearings instaed of one.
Anyone with experience?
Forum rules
- Has thanked: 35 times
- Been thanked: 10 times
- Has thanked: 36 times
- Been thanked: 1336 times
Re: Custom Works GBX Differential
i don't know if one is better than the other but both will work. just make sure if you go with cw that you get gbx outdrives, not gsx.
i would assume the mrp ripper outdrives would work too since it's more or less just a re-badged t3.
Thanx for the info!
It's just that I heard negative things on this forum about MRP's quality. With important stuff like outdrives I'd rather not take risk's.
I'll go for the gbx outdrives then!
- 512 Views
Last post by lpddpd
- 2421 Views
Last post by nikos2002
- 1911 Views
- 2036 Views
Last post by dldiaz
- 4004 Views
- 3345 Views
Last post by SLIDER
- 1045 Views
Last post by mytimac
- 38 Replies
- 7499 Views
Last post by dillonhoffman
Users browsing this forum: Amazon [Bot] and 3 guests
