Please help identify RC10 nuts
kink
Post by kink »
This info is not in the manual. What is the correct part number for the x4 large black plastic nuts which keep the rear suspension blocks in place?
My car has the A&L conversion so maybe the nuts are different, but I am not sure? Anyway those nuts do not come with the A&L kit.
Thanks!
GARBO 1/8
Lonestar
Has thanked: 623 times
Been thanked: 171 times
Re: Please help identify RC10 nuts
Post by Lonestar »
kink wrote:This info is not in the manual. What is the correct part number for the x4 large black plastic nuts which keep the rear suspension blocks in place?
Thanks!
metal 8-32 plain nut 8182 on the 10T
(I think none on the 10, 8/32 screw only bolts in rear block)
Paul
kink
Post by kink »
Hi, yes I am using 8/32 screws which fit into these large plastic nuts. I guess I may have to search ebay for anything which says 8/32...
GARBO 1/8
kink
Post by kink »
Thanks guys.
I also just found out those nuts also fit my 1/4" rear UJ shafts.
:D
GARBO 1/8
Lonestar
Post by Lonestar »
kink wrote:Thanks guys.
:D
use nylocks on wheel axles ;)
kink
Post by kink »
You mean the steel nuts with nylon inserts? There are better than the all nylon nuts?
ps
Anyone know what size of thread / nuts are on the front axles of a 1994 World's?
GARBO 1/8
peetbee
Post by peetbee »
kink wrote:You mean the steel nuts with nylon inserts? There are better than the all nylon nuts?
For a runner then yes, the best nuts to hold the rear wheels on are the steel nyloc nuts, the all nylon ones aren't strong enough imo
kink
Post by kink »
Ok thanks. Ordered steel nylocs!
GARBO 1/8
kink
Post by kink »
Can someone let me know what thread the front nuts are please? (1994 Worlds)
GARBO 1/8
Phin
Has thanked: 87 times
Been thanked: 248 times
Post by Phin »
4-40 for the steel axles, 5-40 for the aluminum.
kink
Post by kink »
Thanks! I have the alloy front axles. Off to ebay for nylocs... :D
Got some Losi 5-40 nuts.
Thanks all, I'm done :)
GARBO 1/8
there's nothing really wrong with using a full nylon nut for a wheel nut. losi's came like that right from the factory. associated's aluminum front axles come with them, i've used them like that for years and never lost a wheel. but if you take the wheels on and off a whole lot, replace the nut every now and again.
same with the rear, i've used nylon 8-32 nuts on the rear axles for weight savings. when they'd start getting a little too easy to wrench on, i'd install new ones.
steel or aluminum nyloc nuts wear out the same way too. the steel ones just weigh more. :mrgreen:
kink
Post by kink »
Eventually I'll try and replace all hardwar with titanium. But I have spent enough recently!
GARBO 1/8
Y'ernat Al
Has thanked: 7 times
Been thanked: 17 times
Post by Y'ernat Al »
kink wrote:Eventually I'll try and replace all hardwar with titanium. But I have spent enough recently!
I read this title thinking most people subscribed to this board would be identified as such. But please don't go replacing factory aluminum and nylon stuff with titanium. You'd be the nuts one then.
- Brian -
My Gallery
Return to “Identifications”
