get vintage t3 or new t3 remake??
- longboardnj
found some old pics and saw t3 posts so i thought id post. people seem to love the t3 so i wanted in. mrp made a truck about 90% t3 called the ripper and it was being sold for $99 rtr so i bought 1..
- longboardnj
Re: get vintage t3 or new t3 remake??
all in all great deal and a great start in the hobby with the least amount of cost. sad part was cause the truck was so cheap and i saw my buddy bash the heck out of t3s i went very rough on the truck. first thing to bust was the rear mounts/rear chassis section. many other parts like top shaft ,slipper, pinion gear, and motor went bad. so i figured worst case id take the bearings out to put in another rc10 only to find out they put a off beat sized bearing in the center/idler gear(pretty sure idler gear and top shaft use same size bearing on t3). left them bearings in, replaced the rest with bushings. then gave the truck to a guy i worked with to get him started in the hobby. so fun truck to play around with,and alot better then starting out with a toysrus rc. just not the t3 we know kinda a sheep in wolfs clothing
- RC10th
- Has thanked: 55 times
- Been thanked: 1587 times
That looks like the Thunder Tiger truck. I always wondered if the Thunder Tiger metal rear plate and nose plate are the same as the T3 or "cheaper"
- Has thanked: 35 times
- Been thanked: 10 times
TT uses an other plate, it's plastic and won't fit on an RC10. They offer an upgrade metal one, but then you'd also need the Rear Suspension Mount Set (3° Toe/3° Anti-Squat) ASC9267. Other option is to use the Asso rear chassisplate (9241) and Asso motormount (9245). I personally would go for this one!
TT idler gear uses metric bearings and diffrent shaft. rest of the gears is interchangable.
good luck,
ps sorry for my lack of english
good luck,
- teman
- Been thanked: 6 times
Original T3, I wouldn't buy a clone since there's just no way it can take the punishment that an original can. For instance, I tried out a TT chassis just to see how long it would last on a T3... 1 month
I allmost bought a TT around X-mas time for the kiddo then remembered what happened to the chassis so I decided to restore a T3 for him instead.
-Kevin
- longboardnj
after the rear broke on the mrp/t3 i put on a metal t3 rear. i didnt know it was a different shaft for idle gear too.. yea id stay away from the tt t3 now even if it was a great deal. my thing is i dont like ball diff bashers so no more t3s for me ill stick with my t4s for bashing.broodenburg wrote:TT uses an other plate, it's plastic and won't fit on an RC10. They offer an upgrade metal one, but then you'd also need the Rear Suspension Mount Set (3° Toe/3° Anti-Squat) ASC9267. Other option is to use the Asso rear chassisplate (9241) and Asso motormount (9245). I personally would go for this one!
good luck,
@ longboardnj: I'm not too familiar with T4's, but i thought they also use a ball diff?
@ teman: so TT chassis is crap? does TT use an other kind of plastic? plastic doesn't look/feels different at all.... Where can i get an original new T3 chassis these days?
- longboardnj
t4 rtrs use gear diffs t4 race kits use ball diffs.broodenburg wrote:@ longboardnj: I'm not too familiar with T4's, but i thought they also use a ball diff?
longboard, I suggest a used t3. I just picked up a TT t3 front body mount and the material is noticeably cheaper, similar to Tamiya
I am truly amazed that I have not broken more parts on my t3.
- teman
The carbon formula seems different to me and they don't make carbon composite versions of anything.broodenburg wrote: @ teman: so TT chassis is crap? does TT use an other kind of plastic? plastic doesn't look/feels different at all.... Where can i get an original new T3 chassis these days?
I snagged a new chassis off the bay last week, but I waited quite a while for that one to pop up. Rollers go pretty cheap, you could grab one to restore or just flip the parts you don't want. I know Sheldons Hobbies has some B3 chassis left, you could call the to see if they have any T3's left.
-Kevin
- 925 Views
Last post by hugger19
- 26 Replies
- 2242 Views
Last post by Helge
- 72 Replies
- 12603 Views
Last post by ron
- 133 Replies
- 49152 Views
Last post by TRX-1-3
- 74 Replies
- 9004 Views
Last post by 1911Colt
- 1577 Views
Last post by sdrob
- 2688 Views
Last post by THE H.P FREAK
- 1961 Views
Last post by JimTMich
Users browsing this forum: No registered users and 22 guests
