Assembled rears
Assembled fronts
Alongside each other
Another interesting fact about the design of these is the threaded ride height adjusters are kept in place by having thread/plumbers tape wrapped around the threaded bodies, rather than an o ring like more modern shockskeithrc wrote:I haven't seen those before, I thought Equaliser shocks were the plastic body ones that came on the Optima Mid Custom.The Lazer ZX and ZX-R came with the gold shocks, the ZX-RR came with upgraded shocks in a browny/grey kinda colour. Maybe yours came on the Lazer Alpha or Sport?
Keith
A very valid, and perhaps likely eventj0pp3 wrote:Maybe they were just Option House shocks and didn't came with any model as standard.
I have a Turbo Optima that is awaiting quite a bit of work, currently has some sort of home made front shock tower and what look like black Tamiya shocks on it, so they may find there way onto it, as it also has a belt drive conversion, so instead of being purely original, it will be built a bit more modern maybe, will see what happens when I start the resto, cheersHKS_TRD wrote:Thanks for posting those pics up, I have the same ones sitting here NIP, along with the short ones as well.
I never knew what they looked like built up.
I have blue caps for them too
I have no plans for them now so its just the excuse to start a new project, what are you planning on putting them on?
They certainly felt aluminium, but that story about the platinum's is scary, maybe they are some other kind of alloy that doesn't like chemicalsHKS_TRD wrote:Are the bodies on these Aluminium? Wondering if I could polishand/or anodise them and put them on my Turbo Optima Mid SE-X. I recall someone saying they found out the hard way that the body of Platinum shocks is not aluminium when they dissolved whilst being chemically cleaned prior to anodising.
Whats the ZX-RR rear suspension mod? I didn't think the ZX-RR had Equalizers? My understanding is it was the fronts which needed the spacersisobarik wrote:They came standard on the Pro-x and probably the Pro-xrt but not sure
same as the grey before just threads i have even seen the the ones with out threads have the same number and header.
the rear shocks should have an insert since the rear shockshaft are longer compared to gold due to lazer zx-rr rear suspension mod.
have those too .
if my memory not letting me down jamiebooth should have had those on his triumph in basildon with the purple/pink colors instead of the black.
mvh isobarik
