extended front tower
- DMAT
- Been thanked: 4 times
Can I get a top down picture of the front shock tower that accepts the 1.02 shocks.
Preferable with a ruler next to it for size reference.
Additional pictures of it will be helpful too so i can properly design one. They may be hard to find but I bet I could have them made.
- RC104ever
Re: extended front tower
No need, they can be bought at rccarbonworks.com
- Chris
Lots of cars...so many cars
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
Pretty sure he's looking for a tower for a buggy nose plate not a WOIN is build. Last I checked RCCW doesn't make those.RC104ever wrote:No need, they can be bought at rccarbonworks.com
- DMAT
your kidding right??? was told those were for the 0.71" shocks
someone here done misinformed me if that is true.
thank god i didnt buy the rc10t front tower trying to make a 1.02 work then.
http://rccarbonworks.com/store/index.php?route=product/product&path=20_36&product_id=104
this one will run the 1.02 shocks? only asking this b/c i dont know the intended mounting hole with this tower. If its the farthest outside for 0.89, then the farthest inside should barely accept the 1.02 at full length.
The car this part is for is definitely not stock. I'm all over the place with parts on it.
If it doesnt work, again looking for some pictures.
- DMAT
yes, it says 0.89, thats why I asked about the mounting hole?
Its only a 5mm-6mm difference in total lenght. The hole distance might cover it.
- Has thanked: 1129 times
- Been thanked: 3919 times
If your designing towers anyway, make a larger than needed piece of cardboard and mount it as a shock tower. Measure a full extended and full compressed shock of your liking. Measure from the center arm hole at full droop with the extended measurement and draw and arc on the cardboard. Then, compress the arm, and using the compressed measurement of the shock, draw a other arc. Where those points intersect gives you the full range of shock and travel. Make a few holes around that one for adjustability.
- Phin
It's more like an 11mm-12mm difference between a GT front shock and a B4 front shock.DMAT wrote:yes, it says 0.89, thats why I asked about the mounting hole?
- Has thanked: 36 times
- Been thanked: 1318 times
that's not how it works. the bottom row is for .71's, top is for .89's. you need to make a taller tower to put 1.02 holes up higher.DMAT wrote:this one will run the 1.02 shocks? only asking this b/c i dont know the intended mounting hole with this tower. If its the farthest outside for 0.89, then the farthest inside should barely accept the 1.02 at full length.
- DMAT
thanks for the info scr8p.
guess ill just design my own. I was wanting it to be close to the andy's version you talked about. I can just use the stock tower as a base starting point.I've got a car tore apart at moment and ill be bringing up to work to model it. That will make an interesting picture once its all done.
I really wish I had inventor at work. Would be nice to assign each part a material so it could prerender it before hand since I've not tried rendering using autocad.
- RC104ever
Sorry was thinking you meant this one and not the worlds style one:
http://rccarbonworks.com/store/index.php?route=product/product&path=20_36&product_id=114
- Chris
- DMAT
c I'm still gonna design one up but id like to get a tower that accept the 1.02 whether its that one or the rc10t front tower.
screw it, i bought one anyways. RCCW usually gets my order to me in ~3 days.
- RichieRich
- Has thanked: 39 times
- Been thanked: 25 times
- DMAT
clearly buying one means i didnt get the message
also, apparently not elaborating on everything possible gets you flamed so thanks for that guys.
- 19 Replies
- 2963 Views
Last post by j.d.roost
- 2051 Views
Last post by longboardnj
- 1515 Views
Last post by Chickenpuff
- 1716 Views
Last post by tamiyadan
- 1022 Views
Last post by Daddeo
- 837 Views
Last post by Joksa
- 1628 Views
Last post by MelvinsArmy
- 651 Views
Last post by mrlexan
