eBay Germany Worlds Car beater
- Mr. ED
- Has thanked: 58 times
- Been thanked: 56 times
Re: eBay Germany Worlds Car beater
I think there was a thread on the forum explaining how to use a later slipper (using a diferent top-shaft).
All recent cars use dual-slipper paths. I guess that has to do with the wilder moters of todays, but it could just be for smoothness too.
sorry it's not a complete suggestion, I hope it puts you on a good path.
Looking forward to the pics you'll make, right?
- Minicooper 35
That was a valuable answer, thank you! Found it in the Useful links section.Mr. ED wrote:I think there was a thread on the forum explaining how to use a later slipper (using a diferent top-shaft).
http://www.rc10talk.com/viewtopic.php?p=13007#p13007
Wil try that in case I am able to collect the parts in time.
Thanks
Seb
"The things you own, they end up owning you."
- Minicooper 35
Seems like Hoopty fall in love ...badhoopty wrote:i still cant get over how freaking cool that mk1 buggy is...
But from what Michael told me there are no cars left. The B2/Yokomo based one was the last Vitec left and it was destroyed two years ago by one of his drivers unfortunately.
- Mr. ED
The MK I seems like something we could still recreate if he'd share the plans...
We really need to get Siebenelch to put up up a thread of his own so we can stop fowling yours Sebastian
- Minicooper 35
Hi everybody!
I decided to go LiPo and Brushless now. The mildest wind I have around here is a 6.5 Turn. A 7.5T ot 8.5T would be more suitable because of the technical indoor track but I am not able to get hold of some before the race meeting. I will rebuild the differential next up and with a mild setup of the speedo and a proper slipper setup the Stealth should not create any problems. Hopefully.
- Has thanked: 28 times
- Been thanked: 947 times
i don't see why you would have a problem with the stealth. the newer versions (b3,b4) can handle the power.
- Mr. ED
I wouldn't worry about the stealth half as much as about being able to keep it under control myself
Not much use in a gearbox that holds up if you can't avoid crashing into stuff.
(note: this is not a negative comment about your choice of equipment, just a reflection on my own capcity as a driver, right after my initial reaction: "Iwish I had stuff like this".)
Go beat'm tiger!
Go beat'm tiger!
- Minicooper 35
Dunno. Maybe it is the usual fear of us male beings of not being properly equipped to do the task ...scr8p wrote:i don't see why you would have a problem with the stealth.
- Minicooper 35
No worries dude! Without working in the model industrie I would not be able to install LiPo's or modern brushless equipment. Maybe I would still use 3000mAh Sanyo's, my old-and-trusted LRP QC1 and a Trinity D3. Well, speaking of that I think it might be a better choice ...Mr. ED wrote:(note: this is not a negative comment about your choice of equipment, just a reflection on my own capcity as a driver, right after my initial reaction: "Iwish I had stuff like this".)
No, dont do that. Go LiPo and BL. I tried that last Thursday at OUR track. It worked very well. I used a 12T BL motor instead of a 6.5. But you might be able to get it hooked up if you use a low power setup on the esc. By the way, the body looks killer, or kinda sick.
Keep it up sugar boy!
FJ
FJ
- Regular Member
- Minicooper 35
Bingo! Traxxas TCP and SRT parts to be precise!liquidrc.com wrote:your front castor blocks are from a Traxxas. Bandit I think.
- Attachments
- Picture 2.png (53.27 KiB) Viewed 1015 times
- Picture 1.png (71.47 KiB) Viewed 1013 times
- Mr. ED
Damn, still nobody has tried rebuilding one of these?
PRP this is exactly the kind of project I expect from you, when will you get started on it ?
- 809 Views
Last post by Asso_man!
- 28 Replies
- 3402 Views
- 69 Replies
- 6865 Views
Last post by jasen
- 1078 Views
Last post by XLR8
- 2437 Views
- 2297 Views
Last post by TRX-1-3
- 221 Views
Last post by mikedealer
- 1090 Views
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Google [Bot] and 2 guests
