'91 Composite Craft/RPM Worlds build
- JPAE07
Re: '91 RPM Worlds build
I think you might be giving RC Carbon Works too much credit by putting their sticker on that chassis.
Yea I know and agree, I asked Kim at Composite craft for decals and never saw a thing so I threw the Carbon works decal on there. It'll be removed along with most of the RC carbon works parts shortly. Not to bad mouth them but I should have bought something heavier.JPAE07 wrote:I think you might be giving RC Carbon Works too much credit by putting their sticker on that chassis.
Yeah I just went to their site looking for the chassis....hahaJPAE07 wrote:I think you might be giving RC Carbon Works too much credit by putting their sticker on that chassis.
- askbob
vsefiream wrote:Yea I know and agree, I asked Kim at Composite craft for decals and never saw a thing so I threw the Carbon works decal on there. It'll be removed along with most of the RC carbon works parts shortly. Not to bad mouth them but I should have bought something heavier.JPAE07 wrote:I think you might be giving RC Carbon Works too much credit by putting their sticker on that chassis.
Aaron has some fantastic shock towers for sale in the BST area. Diggn' the purple screws!
- ClemsonRC10
- Regular Member
I'm definitely feeling inspired by this build. I am currently in the middle of a gold pan runner build, .... and it just veered off course! LOL Ordering one of these chassis for my runner instead.
- JPAE07
That's interesting I've tried getting ahold of Kim via email several times to acquire a couple of these chassis'. I guess I should change methods.ClemsonRC10 wrote:I'm definitely feeling inspired by this build. I am currently in the middle of a gold pan runner build, .... and it just veered off course! LOL Ordering one of these chassis for my runner instead.
- ClemsonRC10
- Regular Member
I was planning to order Friday. Hopefully I will have better luck than it sounds like you have....JPAE07 wrote:That's interesting I've tried getting ahold of Kim via email several times to acquire a couple of these chassis'. I guess I should change methods.ClemsonRC10 wrote:I'm definitely feeling inspired by this build. I am currently in the middle of a gold pan runner build, .... and it just veered off course! LOL Ordering one of these chassis for my runner instead.
- Has thanked: 28 times
- Been thanked: 946 times
most of the parts on your gold pan runner will not work on that chassis. just throwing it out there in case you weren't aware.ClemsonRC10 wrote:I'm definitely feeling inspired by this build. I am currently in the middle of a gold pan runner build, .... and it just veered off course! LOL Ordering one of these chassis for my runner instead.
- ClemsonRC10
- Regular Member
My inexperience with these cars is showing . LOL Thanks for the info. Still considering this though....scr8p wrote: most of the parts on your gold pan runner will not work on that chassis. just throwing it out there in case you weren't aware.
I can't seem to locate a website to purchase one of these chassis.
In Christ,
Joel C.
Joel C.
- JK Racing
- Has thanked: 103 times
- Been thanked: 199 times
Thanks buddy. I knew I could count on you homie. Have a wonderful Thanksgiving.JK Racing wrote:Joel, contact them here
https://www.facebook.com/pages/Team-Composite-Craft/132259133489198
In Christ,
Joel C.
Joel C.
Thanks for the comments guys.
Just a couple bits of info:
1- This chassis is designed to use the RPM worlds parts which are getting harder to find. I found a complete car with a less than stelar chassis as my starting point. See my earlier posts
2- A couple guys have been trying to order this chassis and been having a tough time. I contacted CC through Facebook then called directly per their reply. I gave them a credit card at time of purchase. I spoke with Kim last month on Mini's behalf and the production is slow. CC needs at least 4 orders per carbon style before they cut. This was not the case when I ordered as far as I knew. I would suggest calling CC for details.
Id love to see a few more of these chassis out there!
- Has thanked: 135 times
- Been thanked: 23 times
CompositeCraft Inc.
6127 Anno Ave.
Orlando, FL. 32809
407-857-5343
compositecraftinc.com
[email protected]
6127 Anno Ave.
Orlando, FL. 32809
407-857-5343
[email protected]
Its all fixed up. Thanks to Aaron for some killer shock towers!!
I corrected the front steering linkage, swapped the B3 slipper for a B4, and swapped to stiffer silver springs. I added some travel limiters to the front shocks in an effort to keep the front end down and increase steering response. I also swapped to matching hole shot front tires for improved grip. The rebound is a little slow in the rear yet. I may have to change to a lighter oil in the back. Lastly I swapped most of the aluminum hardware out of the front end in favor of steel. Bent screws in the upper plate brace were my concern for doing this. I also needed to lock nut the shock tower screws so the aluminum hardware was replaced with longer steel screws and lock nuts. I feel the weak spots have all been corrected.
I keep adding to this post... I'll try and keep all the tweaks I do to the car if only for my own record. One last thing I just remembered is the fact that the transmission came completely loose from the chassis and brace and was wobbling around in it's location. This happened just after the second heat. I was able to locate M3 screws for the bottom and slightly longer 4-40 screws in stainless for the trans brace. I'm sure all the abuse the car took didn't help but I think the trans may have been a bit stripped in it's life prior to this car. I also feel that I get a better grip from a steel screw than I do from an equal length aluminum screw. Has anybody seen this before?
I am looking forward to racing this Sunday! They change the layout every three weeks to keep it fair and interesting. I hope to get some video this weekend
- 47 Replies
- 2258 Views
Last post by jcwrks
- 26 Replies
- 2701 Views
Last post by MarkyDents
- 853 Views
- 2511 Views
Last post by asashaw
- 1826 Views
- 564 Views
Last post by Lavigna
- 26 Replies
- 2628 Views
Last post by wyldbill
- 105 Replies
- 11827 Views
Users browsing this forum: Ahrefs [Bot] and 1 guest
