Kyosho Outrage Replacement Wheels & Tires
Hi everyone, Im a newbie so pleaase bear with me. I have 2 vintage Kyosho outrage and I need to find replacement rims and tires, the front rims and tires are 1.9 but it seems like 2.0 from will fit. I am also looking for rear rims and tires any help is greately appreciated.
- losiXXXman
- Been thanked: 5 times
Re: Kyosho Outrage Replacement Wheels & Tires
Welcome to the forum. There are long and short answers to your ??s. Do you want to stick with 1.9 wheels and have to constantly be on the lookout for tires? OR update the car with modern 2.2 sized wheels and tires (readily available)?
Here's an outrage w/ 2.2s:
- Mr. ED
- Has thanked: 62 times
- Been thanked: 62 times
There are about half a dozen threads in this forum about how to put modern rubber on the ultima.
And whatever applies to the utlima counts for the outrage as they are identical in this aspect.
- Regular Member
- Has thanked: 4 times
Hello im new to rc world and i have in my possession my uncles 30 yo outrage.losiXXXman wrote: ↑Sat Mar 30, 2013 11:46 am Welcome to the forum. There are long and short answers to your ??s. Do you want to stick with 1.9 wheels and have to constantly be on the lookout for tires? OR update the car with modern 2.2 sized wheels and tires (readily available)?
Can you please send me a link for the front and rear shock stay because i dont want to make any mistake, can you install the original body with this mod? I would like to ask you what type of spacer you inserted in the shock absorbers bulbs because i cant find.
Thanks
- losiXXXman
These shock towers are the ones form the Ultima Pro. You will find that almost every hop up the fits the Ultima, Ultima Pro, and Ultima Pro XL will also fit the outrage. Since Kyosho has re-released the Ultima, it should be easier to find replacement parts. You can also upgrade to the re-release transmission which would give you sintered aluminum 48P gears, a sealed oil filled gear diff, and a slipper clutch. You can even get a ball diff as the one from the Optima re-release fits I'm told.
If you want a set of the shock towers newly made, pm the user on here gomach5. He is also the ebay seller factoryworksrc.
Have fun with the car. I had an Ultima Pro that I loved, but got frustrated looking for good parts, and gave up on the re-release of the Ultima to materialize about 18 months before it came out.
- 3437 Views
Last post by bunnyboy
- 1607 Views
Last post by isitafox
- 2019 Views
Last post by radioactivity
- 831 Views
Last post by MrRadar
- 1782 Views
Last post by outrage-bl
- 932 Views
- 1915 Views
Last post by Diggley
- 3414 Views
