Looking for very dark gunmetal / not quite black
kink
Post by kink »
I have seen medium shade greys and gunmetal colours. I have also seen lots of plain jet blacks. But is there a lexan paint shade which is in between? Closer to black than grey (maybe 80% towards black) and ideally metallic. Just an off the shelf rattle can please.
Thanks!
GARBO 1/8
Has thanked: 3699 times
Been thanked: 1980 times
Re: Looking for very dark gunmetal / not quite black
You could maybe back up window tinting with another color. I'm not sure what would be the best choice though. Maybe a more experienced painter could suggest how to back it, or a better color altogether.
http://www.testors.com/products/137988
I have used metallic black lexan paint before. You could do a light coat or two of metallic black, and then back it with silver to get the shade you are looking for maybe?
http://www.testors.com/products/573433
how about that color?
justinspeed79
Post by justinspeed79 »
I just mix silver and black to get a gunmetal color.
THEYTOOKMYTHUMB wrote:You could maybe back up window tinting with another color. I'm not sure what would be the best choice though. Maybe a more experienced painter could suggest how to back it, or a better color altogether.
I don't recommend this. I tried window tinting from Pactra and that stuff was absolute sh!t. At least the rattle-can I had, something was very wrong with the formulation--or maybe it's normal that 2 minutes after you spray it on a perfectly clean body, it collects in small dot-like pips everywhere. I even tried spraying it INSIDE a plastic bag so there was zero chance of this being caused by floating dust motes, but again--within a few minutes, I saw it dry in dozens of little pips. I also don't think the tint is intended to have a backing coat as it's supposed to be transparent.
kink
Post by kink »
Thanks for the suggestions. But I have also had poor experiences with window tints. Also I do not wish to mix colours as it will not be perfect. If there is no off the shelf solution I'll have to pay a pro air brusher, who will no doubt blend something before spraying. Or have a rethink!
GARBO 1/8
