Arm/Hinge Pin difference?
- esaresky75
Why are there two part numbers for the outer hinge pin for the rear arms? Part # 7357 or 6381.
Burn more coal - UnderGroundMiners.com
- Has thanked: 36 times
- Been thanked: 1318 times
Re: Arm/Hinge Pin difference?
isn't one for a buggy (6xxx) and the other for a truck (7xxx)? they are different.
- marlo
- Has thanked: 18 times
- Been thanked: 22 times
One pin might be for the older rear A-arm, then I think with the world's type a -arm the pin was longer( might be the same for truck ) due to more material added on the arm
- esaresky75
it's an early/late deal. the arm number is different too. early arms used buggy pins........ that's what i get from it.
- esaresky75
Look closer, the other number is for the e-clip.marlo wrote:Also two part numbers for the inner pin.
or it could be nothing more than a "these will also work". just be a little long.
- esaresky75
For $2.79, I'll order each part number.
- Has thanked: 1129 times
- Been thanked: 3919 times
The original arms used a shorter pin, and the wheelbase was not adjustable. The later flat arms have a spacer that allows the hub to be moved fore or aft to change wheelbase and thus a longer pin. This is going off the top of my head
ya, that's the buggy pin (6xxx - i mixed them up above). the early truck arms used the shorter pin (7xxx), same as the rpm worlds/dynotech klein arms.gomachv wrote:The later flat arms have a spacer that allows the hub to be moved fore or aft to change wheelbase and thus a longer pin.
- Charlie don't surf
- Has thanked: 358 times
- Been thanked: 470 times
Trucks always had adjustable wheelbase, I'm pretty sure your talking buggy...but just to avoid confusiongomachv wrote:The original arms used a shorter pin, and the wheelbase was not adjustable. The later flat arms have a spacer that allows the hub to be moved fore or aft to change wheelbase and thus a longer pin. This is going off the top of my head
- marlo
esaresky75 wrote:Look closer, the other number is for the e-clip.marlo wrote:Also two part numbers for the inner pin.
- 743 Views
Last post by Ronborsk
- 1007 Views
Last post by KidAgain
- 912 Views
- 1243 Views
- 2179 Views
Last post by XLR8
- 827 Views
Last post by knucklebuster
- 485 Views
Last post by bscotti
- 2043 Views
Last post by TRX-1-3
Users browsing this forum: Amazon [Bot] and 20 guests
