Kyosho Gold Rebuild ??
losiXXXman
Post by losiXXXman »
Tore out the seals on my golds, and don't have any rebuild packs, SO, thought I'd go check the spare parts bin (oops, I mean trash) at work. What size are those retaining rings for the seals?
EvolutionRevolution
Has thanked: 17 times
Been thanked: 34 times
Re: Kyosho Gold Rebuild ??
Post by EvolutionRevolution »
Aren't the O-rings 3mm inner diameter?
He might be referring to the thin steel spring clips that you install on the bottom of the shock body, that hold everything inside. I don't know the size but could measure later on this evening.
losiXXXman
Marc, you hit the nail on the head. An alternative to the spring clip is what I was looking for. I couldn't find any metric internal rings, but got a couple std ones that look close. The kyosho w5018 kit would do it, it's ony $6, but kyosho America's minimum postage is another $6. :roll: . I assume the associated kit wouldn't work, but IDK, maybe. What about this traxxas kit?
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXJJ17&P=ML
How many spring clips do you need? I could probably spare a couple.
Return to “Kyosho Forum”
