Sometimes you eat the bear, and sometimes the bear eats you
- RC10resto
- Has thanked: 1488 times
- Been thanked: 550 times
Re: Sometimes you eat the bear, and sometimes the bear eats
I learned that one on a set of early JRX2 wheels
- Been thanked: 325 times
Great idea for a topic; post your biggest screw-ups!
Let's be honest, we've ALL effed something up a time or two, haven't we?
- Has thanked: 1129 times
- Been thanked: 3919 times
Ever spray a dirt thrasher with motor cleaner? I did. Once. The parts turned white, thought it was strange. Went to drive it and the first bump the car literally shattered into a million pieces. I wish I had taken a pic.
- Has thanked: 36 times
- Been thanked: 1318 times
i have a front cap to replace the melted one if you want it. got a rear one too, but it has 2 holes drilled in it.
That's really kind of you Jason, I may have to take you up on the offerscr8p wrote:i have a front cap to replace the melted one if you want it. got a rear one too, but it has 2 holes drilled in it.
This was also the final step of a restore that's been going on for 5+ years, typical
- prp
- Been thanked: 13 times
Oh you don't need to boil the peroxyde to rewhite the parts,
Only put in a closed bottle under the sun, 1 or 2 days according to the color you need...
After treatment you need to let the peroxide clear from the parts, i do this by boiling them afterwards to speed up the process. if you don't and you put them near anodized parts the peroxide vapors will remove the anodized finish.prp wrote:Oh you don't need to boil the peroxyde to rewhite the parts,
It's a known issue.
- EvolutionRevolution
- Has thanked: 17 times
- Been thanked: 34 times
Flush under the tap for about 10 minutes. That should be enough (at least, it was enough to remove the peroxyde from biological tissues at the lab some year ago when I did that
I once tried to dye some wheels black. I used a recommended product yet it turned out terrible. The white wheels ened up patchy dark blue / black. I decided there and then I would never trust any sort of dye again. I am only glad the wheels in question were not rare or expensive! No way I'll be boiling any plastic parts either! Way too dangerous for me.
GARBO 1/8
Plastic parts shouldn't be boiled. Nylon is good to go, though.kink wrote:I once tried to dye some wheels black. I used a recommended product yet it turned out terrible. The white wheels ened up patchy dark blue / black. I decided there and then I would never trust any sort of dye again. I am only glad the wheels in question were not rare or expensive! No way I'll be boiling any plastic parts either! Way too dangerous for me.
err.....well.....nylon is a plastic.
so you are OK to boil nylon, pure nylon, not a blend, as it has a higher melting point, and in fact can absorb water, helping to make it flexible. Other plastic blends and pure plastic types (such as ABS) have a lower melting point, which is the other popular injection molded toy/hobby plastic. These blends do not absorb water and will start deforming as evidenced above around 200 degrees (F).
ill have a front and rear for ya as soon as i get the rpm kit from prp
- 3141 Views
Last post by coxbros1
- 541 Views
Last post by THUNDERSTRIKE1
- 3063 Views
Last post by yellowdatsun
- 1240 Views
Last post by vmt79
- 26 Replies
- 4529 Views
Last post by silvertriple
- 22 Replies
- 3874 Views
- 1415 Views
Last post by klavy69
- 3126 Views
Last post by YZ-10
