it is possible to run B4 trans in old rc10
maybe new shock tower with hole for the wing and hold the trans or something close?
tranny question?
Re: tranny question?
there are a bunch of threads where guys have done that pretty easily.
you would need to either cut a hole in the bottom of the chassis, or mount the trans on a small plate with a hole to allow the trans to sit 'flat' on the chassis, and then modify the bulkhead or fab a new rear bulkhead. you may also need to trim some of the chassis or bend some small plates to attach the motor plate, and perhaps a bracket to help tie into the rear bulkhead.
jwscab wrote:there are a bunch of threads where guys have done that pretty easily.
thanks for the reply... it is possible for you to re direct me to those treat to see the correct one I have a graphite chassis? thanks
- soniccj5
You might want to check out Toasted Coasties build.
http://www.rc10talk.com/viewtopic.php?f=35&t=16956&hilit=b4+transmission&start=15
thankssoniccj5 wrote:You might want to check out Toasted Coasties build.
- 1158 Views
Last post by popboy905
- 1101 Views
Last post by Dave145
- 1066 Views
Last post by Sixtysixdeuce
- 946 Views
Last post by lexus-5
- 1232 Views
Last post by Erich Reichert
- 942 Views
Last post by Bugle
- 623 Views
Last post by glowster21
Bing [Bot] and 9 guests
