Novak Racer EX,Trinity Monster Horsepower pink lable gearing
well i have a novak racer ex hyper fet esc and a trinity monster horsepower pink label motor that i have in my rc10t runner with a novak 2 cell smart stop and i need to know a good starting(safe) gearing setup. the spur is an 87 but im unsure as to what pinion to run because i dont remember what the motor wind is and its been so long i dont remember how to check. any gurus out there that can help me out. i wanna run this in stadium truck to freak people out.
do you think its a bad twilight zone episode for team associated to be re producing a buggy from yesteryear that is capable of beating their latest and greatest production buggy?
Re: Novak Racer EX,Trinity Monster Horsepower pink lable gea
bueller?....bueller?....nobody knows the specs or what gearing to use?
- Charlie don't surf
- Has thanked: 356 times
- Been thanked: 470 times
problem is the pink label Trinity motors were wound from like a 7x1 to a 17 x 4, so the gearing is relative to that factor. Any idea what wind it is?GoldRush wrote:bueller?....bueller?....nobody knows the specs or what gearing to use?
i honestly dont remember how to check...internet search is a full of no help either. im not sure what the limit is on the esc but i received both the esc and motor together so im assuming they are happy with each other as long as gearing is correct. how would i check the wind on the motor?
- UserUnrelated
On most of my trinity motors, there's a little piece of paper stuck into the stator that says like "Epic27" for 27T, or "Epic19" for a 19T
The ones that don't have this have it stamped in ink on the stator.
Some of my motor cans have little air vents that act as convenient viewing windows for these little labels.
If it has no vents, and it can be taken apart, take the stator out and look for markings. I only have 2 stators (out of 15 or 16) that aren't labeled.
It may be hand written on the armature, but take the arm out and take a pic...I can get within a wind with a good pic
i checked everywhere...took the motor apart and no markings whatsoever. there is what looks like red marking compound on all 3 faces of the stator and white paint at the end of the windings at the pinion shaft end. at the com area it looks like 2 pieces of wire for every one of the 3 sections so if memory serves me right that means its a double wind. as far as how many winds that is the only question now. any way to determine that without ruining the motor?
i went around the motor to different spots to get an idea and i get about 0.030inch to about 0.035in
Im going to call that a 10x2 or 9 x 2. Stupid hot for 2wd......
dang...im not even sure the esc is rated for that but it came wired together...not even sure what i would run it in now. was hoping to have this thing properly geared and run some practice laps on sunday...im taking a bunch of my old runners out just because a few guys didnt believe that i had a bunch of cool old rigs and that i would never bring them out.
That Novak Racer is a 410- HPC Hyperfet, same esc that won 2wd and 4wd worlds in 93, and masami used a 10 x 2 in 4wd-
Make sure the timing is at 0-8* and run like an 87/15
i found some info on the esc and it says no motor limit so i should be ok...as far as timing its set straight up at 0 degrees. input says 4-10 cells so im assuming a 2s 5000 mah 40c lipo will be fine. thanks for all the help. as far as motor temps since i never cared back in the day what should be a good temp to be at?
its alive and its pissed off fast
- 40 Replies
- 9995 Views
Last post by Frankentruck
- 1530 Views
Last post by bigmd
- 2902 Views
Last post by Joost K.
- 1447 Views
Last post by RC10resto
- 59 Views
Last post by Dangeruss
- 874 Views
Last post by MrBeno
- 246 Views
- 761 Views
Last post by toolman72
