Question about shock angle?
- RC104ever
Re: Question about shock angle?
I would think it would affect the caster angle when it compresses but that's just a guess
- Chris
Lots of cars...so many cars
While I could be wrong but if it affected anything, other than dampening characteristics, I would think it affects camber not caster. On top of that the rear doesn't have caster.
The reason I'm asking, is because I'm modifying my 10t's rear suspension so I can run T4 bodies properly (with out any rubbing, mounting it further forward, or shim it up). I'm testing shimming the rear shock tower forward then mounting the shocks on the back and use the lower GT shock mount to allow the bottom of the shocks to mount within the dimensions of the arms. Unfortunately that limits the rears travel; preventing the chassis from touching the ground.
So I'm also contemplating mounting the shock tower on the back of the bulkhead which would allow me to mount the shocks normally but angles the top of the shock towards the back of the truck.
- Charlie don't surf
- Has thanked: 359 times
- Been thanked: 471 times
unless the shocks are perpendicular to the suspension arm all you effectively do is cause binding in the shock. With that being said your rc10 has built in anti-squat in the rear suspension by way of s slight kick up in the rear toe blocks, so your rear shocks are supposed to follow that slightly bottom forward angle.rcgerber wrote:Front to back.
- RC104ever
Isn't Camber angle side to side and Caster angle front to back?
In any case, I'm no suspension expert, I just go with whatever seems to work, lol
- Chris
Caster is front to back, but I think your referring to anti-squat/anti-dive. Caster is the kingpin angle in relation to the chassis or horizon.RC104ever wrote:Isn't Camber angle side to side and Caster angle front to back?
So if your looking at the left side of the truck (the front to the left) the shock angle if there is any should look like this /Charlie don't surf wrote:unless the shocks are perpendicular to the suspension arm all you effectively do is cause binding in the shock. With that being said your rc10 has built in anti-squat in the rear suspension by way of s slight kick up in the rear toe blocks, so your rear shocks are supposed to follow that slightly bottom forward angle.rcgerber wrote:Front to back.
So do you shim the bottom out when using the long wheelbase holes on the rear mounts to keep the angle good?
Front shocks should look like that (perpendicular to the nose plane) rear with lower spacers
- Y'ernat Al
- Has thanked: 7 times
- Been thanked: 17 times
You could try a new body...rcgerber wrote:...The reason I'm asking, is because I'm modifying my 10t's rear suspension so I can run T4 bodies properly (with out any rubbing, mounting it further forward, or shim it up). ..
http://www.rc10talk.com/viewtopic.php?f=36&t=21998&hilit=bulldog+body
Laying the shock down front to back is essentially loosening up the suspension without much of a progression change (because the anti-squat angle is probably negligible for the amount you are proposing to move the shock-top rearward - and the arms just don't move in that direction like they do when you lay the shocks down in the traditional manner), akin to using a more inward hole on the suspension arm BUT
IMO, get a new aftermarket body style (or maybe some lexan scissors).
Yeah the Jconcept Finisher fits well, but I've never been a fan of the cab forward bodies especially the Proline Bulldog.
Here's a pic of what I'm doing, so the angle doesn't look bad then, and will get a smig better once I tweak the bulkhead.
By the way I love this forum, it's a wealth of knowledge.
Thanks everyone.
Thanks everyone.
Use a flat 4/40 nut behind the FT upper shock bushing and you should be good to go, or grab the longer variation of that bushing. The Jconcepts Interceptor fits extremely well and has a very normal 10T look )
Isn't that a Jconcept Illuzion body. I have one of those, but it doesn't fit correctly, the rear shocks are to far forward. That is why I'm doing what I'm doing. Thanks for the info though.
Looking back to the build thread it has the part # of the illusion (0005) but I had no clearance issues with the rear mounting system I used-
- 1097 Views
Last post by Trackingz
- 919 Views
Last post by askbob
- 2911 Views
Last post by DerbyDan
- 629 Views
Last post by highwayracer
- 1938 Views
Last post by gtrgeo
- 23 Replies
- 1390 Views
Last post by juicedcoupe
- 568 Views
- 510 Views
