What is this? "Hydra-drive"??
Re: What is this? "Hydra-drive"??
a hydradrive works sort of like a slipper, but it doesn't slip. it absorbes shock and protects the drivetrain.
it was invented by team losi and first appeared on the XX (correct me if i'm wrong fellas).
it uses a thick fluid, similar to diff fluid.
- Has thanked: 1129 times
- Been thanked: 3917 times
yup, that ain't no hydra. i've never seen anything like that.
(never ran shuey's either)
Here is the link to the instructions. It was called a "viscodrive"
http://forum.racing-cars.com/forum_posts.asp?TID=9324&title=installation-sheet-viscous-drive
- Charlie don't surf
- Has thanked: 355 times
- Been thanked: 470 times
kaiser wrote:a hydradrive works sort of like a slipper, but it doesn't slip. it absorbes shock and protects the drivetrain.
It was first used on the LXT and Pro SE.
"It is not how you finish but how you qualify unless you qualify bad then it is how you finish."
Words of wisdom from the Cox bros at my local track.
installed to a JRX2/Pro/SE
― Confucius
― Confucius
- 1428 Views
Last post by Synergy
- 1265 Views
Last post by brian s
- 902 Views
Last post by joel45acp
- 688 Views
Last post by radioactivity
- 827 Views
Last post by Mark Westerfield
- 842 Views
Last post by Lonestar
- 623 Views
Last post by ThomasH
- 5377 Views
Last post by Asso_man!
