Couple of questions regarding my WOIN project - Steering
- mdutcher
I am concurrently working on another vintage WOIN project with a gold pan RC10. I have a couple of questions for the experts.
First, I have noticed that the steering rack is cracked where the ball studs go in. I would like to replace them. I have noticed that I could find vintage ones on eBay, but was wondering if there are some good aftermarket options. Are there?
Second, and more importantly, I tried installing some new titanium turnbuckles with some new ball cups. In looking at the original ball cups that I am replacing, I can see that the new ones are bigger. I tried to install the new ones and have found that when steering, the 2 sets of turnbuckles, camber and steering, are hitting each other at certain points. I could move the steering rack back to the back holes, but am not sure what that will do with the steering geometry. What are my options here for when I am trying to use modern RPM ball cups?
If you can help by explaining or showing pictures of what you were able to do, then that would be great.
Thanks!
Thanks!
FT RC10B4.2*Dualsky ESC*Reedy 17.5T*XP
RC10 Re-Re*Dualsky ESC*Reedy 17.5T*Savox
RC10 CE*Novak GTB2*Dualsky 13.5T*XP
RC10T and other vintage goodness
- klavy69
- Moderator
- Has thanked: 639 times
- Been thanked: 294 times
Re: Couple of questions regarding my WOIN project - Steering
you'll have to install the short ball studs on the cranks and the ones they are hitting. There is the same question in another thread with part numbers in it and links to the ones I mentioned. Do a little searching and you'll find it somewhere in the rc10 section here.
found the other thread Here.
- Phin
- Has thanked: 87 times
- Been thanked: 248 times
You can buy A&L bellcranks for the RC10 again which would also solve your clearance problem.
Google Team A&L.
Google Team A&L.
- klavy69
- Moderator
X2. you can get Darryl's parts here, Team A&LPhin wrote:You can buy A&L bellcranks for the RC10 again which would also solve your clearance problem.
Google Team A&L.
- RC104ever
Another vote for team a&l bell cranks, they are awesome
- Chris
Lots of cars...so many cars
- mdutcher
Thank you for the input and the links. It is much appreciated.
- Has thanked: 36 times
- Been thanked: 1318 times
if it's an "old is new" style car with a narrow front end, i don't see how they should be anywhere near one another. not like a stock buggy front end anyway. one of my cars is a tub chassis w/ an rps bellcrank, that alone sits way up off the chassis. even with rpm ball cups there is no rubbing.
seems like you need a new bellcrank anyway, but why don't you post a pic of what you have now?
- 37 Replies
- 6405 Views
Last post by Jim85IROC
- 1714 Views
- 853 Views
- 1191 Views
Last post by bigmd
- 638 Views
Last post by Sharkman
- 1025 Views
Last post by Boredome
- 1636 Views
Last post by mytimac
- 733 Views
Last post by Lowgear
Users browsing this forum: Amazon [Bot] and 11 guests
