Brushless motor, reverse ?
2500M_Sub
Post by 2500M_Sub »
Okay just hooked up my castle 4600KV and Sidewinder 2 in my vintage RC10 the motor runs in reverse, when i pull the trottle so I initially just reversed the channel on the Flysky controller but also read that you can just switch two of the motor wires. I put the channel back to normal and did this but I swear the motor runs faster backward so I did the wire switch back to the normal position and reversed the channel. I now swear it goes faster forward than in reverse. Is reversing the channel a bad thing to do instead of switcing the wires?
Regards,
Ren
RC104ever
Re: Brushless motor, reverse ?
Post by RC104ever »
It doesn't really matter but depending on your ESC settings, that will determine the speed in either forward or reverse.
And with a sensorless motor like the Castle, you can swap any 2 of the 3 motor wires to make it go forward when your ESC is set to normal.
- Chris
Lots of cars...so many cars
klavy69
Moderator
Has thanked: 639 times
Been thanked: 294 times
Post by klavy69 »
RC104ever wrote:And with a sensorless motor like the Castle, you can swap any 2 of the 3 motor wires to make it go forward when your ESC is set to normal.
I had to do this since I had the same situation with a recent 1/8 scale acquistion :wink: Made for a night and day difference.
lpddpd
Post by lpddpd »
Had this happen with a Castle as well. Just switched wires and no problems, although since the wires are colored, it just looks like its wired wrong now. :P
What everyone else already said. The ESC and sometimes motor instructions almost always say to switch 2 wires to reverse motor direction.
