A Stamp caster blocks?
Hello all,
I had my first failure today running my newly restored glod pan when a caster block broke. I did some looking and it looks like the car came with the 6213 15* blocks but doing more reading it looks like using the 6210 30* caster blocks have their advantages of giving more front end bite. It also looks like the 6210's are far easier to get as well. Before I order anything I just want to make sure getting the 6210's is in fact the way to go.
Thanks.
Cheers,
Jim
Thanks.
Cheers,
Jim
- Charlie don't surf
- Has thanked: 358 times
- Been thanked: 470 times
Re: A Stamp caster blocks?
They were 5 and 10*- 30 is more than that front end will accept I believe.
- dldiaz
- Has thanked: 41 times
- Been thanked: 58 times
I agree - 30 degree caster blocks on a stock short arm car will cause the steering knuckle to contact the lower suspension arm (resulting in severely impaired steering throw).
Stick with the 5 or 10 degree caster blocks for the short arm car.
-dldiaz
Copy that....this would be a good reason to switch to long front arms? If I did that what would the ideal caster block to use?
Cheers,
Jim
Cheers,
Jim
I just took apart the broken parts and it looks like the caster blocks are in fact 15* when lined up with a protractor.
Cheers,
Jim
Cheers,
Jim
- 803 Views
- 2560 Views
Last post by 85Edinger
- 461 Views
Last post by m_vice
- 1246 Views
Last post by XLR8
- 1429 Views
Last post by Chewbacca
- 1419 Views
Last post by fredswain
- 729 Views
Last post by klavy69
- 997 Views
Last post by rctodd1624
Users browsing this forum: Bing [Bot] and 3 guests
