If there's metal there in my RC stuff, I like to be reminded of it visually and from the texture!
Anybody else? Lol, Coelacanth, should I just go ahead and cast a vote for you too since I know where you stand?
If you mean stripping off the anodizing and leaving it as-is, then I wouldn't recommend that. Bare, raw aluminum is softer and will quickly show every scuff & scrape and dull with age. Just handling a raw finish will imprint the surface with your fingerprints, the oils will attract dirt and will darken the surface.longboardnj wrote:i was thinking of painting a few chassis.is it bad to paint the chassis?? i was gong to just strip a few chassis and run them raw is that bad???
yea im thinking shelfer paint,runner raw... thanks for your input.. maybe ill try the wax on the bottom/sides.. i usually just scuff the metal and leave itIf you mean stripping off the anodizing and leaving it as-is, then I wouldn't recommend that. Bare, raw aluminum is softer and will quickly show every scuff & scrape and dull with age. Just handling a raw finish will imprint the surface with your fingerprints, the oils will attract dirt and will darken the surface.
If you strip it to raw aluminum and don't want to polish, then I'd at least suggest applying automotive wax to protect the finish. I put wax on my polished surfaces that don't get anodized, such as polished aluminum wheels.
As far as paint goes, I'm not a big fan of painting a chassis because I know it'll show every single scratch & ding. Every new scrape would irritate me. But if it's a shelfer that'll never be driven, I don't see why not.
Users browsing this forum: DotNetDotCom.org [Bot] and 11 guests
