3000Mah enough for stock buggy class?
- Regular Member
Is 3000 Mah enough battery for stock 2wd buggy class? I am looking for a battery that fits in to the chassis of a XX losi that still allows some battery movement for weight distribution. So far the ProTek 3000mAh seems like what I want if it will make a 6min run with a 17.5
- soniccj5
Re: 3000Mah enough for stock buggy class?
I am running 3800 Mah LiPo without any issues. Get about 20-30 minute runtime.
- JK Racing
- Has thanked: 139 times
- Been thanked: 246 times
I ran a 5400 in my XXT before I got rid of the truck....not much room to move it around, but the truck didnt need it either
- Regular Member
- Brandon G
I run this in my X-6 squared with 10.5 brushless:
http://www.amainhobbies.com/product_info.php/cPath/1_25_1450_996/products_id/227787/n/ProTek-R-C-2S-Supreme-Power-Li-Poly-70C-Pan-Car-Battery-Pack-74V-3000mAh
Very light weight, plenty of runtime. I think it'll do 15-20 minutes. Don't know really, never actually timed it. I run 6 minute qualifiers and rarely have to charge more than 1200mAh back into it.
- sgirouard
With a 17.5 in a buggy, you should use approx 1100-1500 mah per heat depending on how you are with throttle and brake.alwaysLOSI wrote:Is 3000 Mah enough battery for stock 2wd buggy class? I am looking for a battery that fits in to the chassis of a XX losi that still allows some battery movement for weight distribution. So far the ProTek 3000mAh seems like what I want if it will make a 6min run with a 17.5
- Regular Member
That is the one I'm looking at thanks Brandon.Brandon G wrote:I run this in my X-6 squared with 10.5 brushless:
- 59 Replies
- 10163 Views
Last post by Zac_F71
- 1952 Views
Last post by sneako43
- 1517 Views
Last post by Eccentric
- 19 Replies
- 4417 Views
Last post by tony13b
- 1235 Views
Last post by ra272
- 1085 Views
Last post by TheSpeedway
- 1869 Views
- 2490 Views
Last post by Riv2SC10
